Results 1 to 10 of 20
May 14th, 2014 09:10 PM #2
Remove loose dirt/dust. Soak/wash with diluted joy liquid detergent and dry. Apply small amount of singer oil.
Sent from my Nokia5110i-VgT using Tsikot Forums
May 14th, 2014 09:14 PM #3
May 14th, 2014 09:31 PM #4
No sir.
Engine oil is a lot viscous, 97 vs 9.6 *40degC. This means pwede magform na gum ang dust sa filter if you do.
May 14th, 2014 11:24 PM #5
The practical move is to use k&n recharger kit. Subok na yan e. Using detergent and other oils can damage your filter or engine.
May 15th, 2014 01:33 AM #6
How do you apply singer oil? Spray it directly to the filter?
Posted via Ay****
May 15th, 2014 01:35 AM #7
kapag oily at sobrang dumi, I sprayed it w/ degreaser then soak/wash it with dishwashing liquid. after washing, I bring it to my neighbors vulcanizing shop and blow dry it with compressor air. kapag sinisipag ako, nilalagyan ko ng recharging oil ;) lately hindi na, I run it dry as it is na lang and ok naman. btw, make sure to clean your MAF sensor too, it makes a lot of difference kapag nalinisan yung MAF sensor.
May 15th, 2014 10:40 AM #8
May 15th, 2014 11:29 AM #9
I use engine degreaser also to clean it then use water & dishwashing liquid for final cleaning. Air dry lang ako na mga 1 day tapos I use 2t oil.
Apply ko lang 2t oil sa topmost part nung filter tapos i let it drip down. After a day okay na yan. First time ko sobrang dami nga 2t na nagamit ko, dapat kunti lang pala, mga 50ml would do. 2 days yan kay may reserve ako na air filter. Every 15,000kms ako naglilinis.
May 15th, 2014 11:57 AM #10
Tesla Philippines
