Quote Originally Posted by gowthead View Post
halos pareho tayo problema.. same engine PH12?,, hatch sa akin 93... di kase ko pumasa sa emission test e dinala ko agad sa talyer...pagkatapos kalikutin ng siraniko at paglaruan ung timing ng walang timing gun nag simula na problema sa auto...inadavance timing, kinalikot taffetes...nilinis sparks.. pinalitan sparkplugs seals... kinabukasan ayaw na magstart kung hindi tapakan gas... tapos pag mainit na makina ..pa putok putok na ung buga sa tambutso.. inadjust ko hangin nawala ung abnormal na buga...pero weird pa din ung idling.. di ko makuha ung tamang balance at timpla..mejo niretard ko na din ung timing (kapa system)....mejo nawala hatak pero nag sstart na sya kaso hindi pa din normal ung tunog pag malamig makina parang super hingalo...pag uminit naman may whiiiiiiiiirrrrrrrrr sound naman pag tinatapakan ung gas (running or idle)....
bro i have the same problem with my car..pero dun lang sa last part ng description mo.. my car got screwed after having my timing belt changed by a wreckanic as well.. when stepping on the gas, may "whiirrrr" sound coming from the timing belt area.. so i figured na baka masikip yung belt.. i had it adjusted, nawala naman although not completely. humina lang.. maririnig mo nlang pag nakataas yung hood. dati kasi kahit nakababa yung hood, rinig pa rin... aside from this, nagkaron na ng oil leak dun sa front part ng timing belt cover..medyo worried nga ko kse baka soaked in oil na yung bagong belt ko.. baka naging useless pa yung pagpapalit ko.. mas napasamang PMS. im planning to have this checked y speedyfix..save lang muna ng konting cash para sabay ko na sa change oil, sparkplugs, and filters... question is, nasolve mo na ba yung problem regarding that irritating "whir" sound? try ko rin sana sa civic ko.. tnx..
