Results 1 to 10 of 11
January 23rd, 2008 12:06 PM #1
Help po...
Ano po kaya ang cause ng tok sound pag nag step ako sa gas pedal? It ussually happen when im on 1st and 2nd gear * low speeds (0-30 km/h).
Thanks in advance...
January 23rd, 2008 03:55 PM #2
imho.. its not connected with the engine. but its with the front suspensions dahil pag 1st and 2nd gear, bigla ang takbo ng oto resulting in jerks.
probable reasons:
a) brake calipers
b) joints
c) bushings and shock mountings
Tsikot Member Rank 5
- Nov 2003
- 3,848
January 27th, 2008 10:20 AM #3maybe engine supports pero hard to say unless you have it physically inspected.
January 27th, 2008 11:06 AM #4
January 30th, 2008 12:22 PM #5
January 30th, 2008 04:36 PM #6
Asking advice from around the web they too have suspected that the cause of this problem would be a loose/faulty engine support.
*speedyfix, any tips on how to inspect the engine support to confirm our allegations?
*vito, have you already brought your ride to a mechanic for inspection?
January 31st, 2008 09:42 AM #8
hindi pa, bro. . .last weekend ko pa lang naramdaman. . .pinacheck ko lang kasi nung nagpalit ng shocks e yung suspension assembly. . .salamat sa info, isasama ko yan sa check point pag dinala ko sa shop for check up. . .tinanong ko sa isang kumpare ko, 2,900 petot daw ang engine support ng lancer (oem parts). . .ewan ko lang sa ibang brand ng car. . .
paano yung pagkabig to one side (in my case, sa kaliwa), symptom din ba yun ng faulty engine support?. . .input mga bro. . .salamat
peace of christ. . .
"THOUGH HOME TO US ALL, THE EARTH IS MUTE.
IT DOESN'T GET A VOTE IN ANY CONGRESS OR PARLIAMENT.
IT DOESN'T OWN BLOCKS OF SHARES IN THE MARKET.
IT DOESN'T RISE UP AT A PROTEST RALLY.
IT CAN'T EVEN BUY A HYBRID CAR.
THE EARTH HAS NO VOICE--SO WE MUST SPEAK FOR IT."
- Jan 2008
- 42
January 31st, 2008 02:49 PM #9
chief yung tok tok sound ko as far as what several technicians advice pang ilalim siya, wala silang advice regarding engine support problem. ang advice sa akin ay mag palit ng stabilizer clam bushing mejo sa looban siya na part. hope this would solve my problem
and i also suggested to repack my CV joints baka kasi lumalala dahil may punit na yung axle boot at lumalabas na yung grease
- Jan 2008
- 42
February 3rd, 2008 12:53 AM #10Mga fellow tiskoteers it was a relief i went to the so called [SIZE=5][SIZE=4]CRUVEN Makati[/SIZE] [/SIZE]which almost everybody recommended and with out any doubts na solve problema ko Thanks to Mang Romy the chief mech, and the rest of the crew. Take note when i got their mismo ang manager sorry but i forgot his name pero maasikaso din when i went there. I just hope wala na akong marinig pang ingay sa car ko. so far the first day was smooth.
Thanks much to Cruven Makati !!!!!!!!!!!!!!
By the way thanks nga pala for the discount
Tesla Philippines
