Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Sep 2004
    gys w/ Civic EK body, have you experienced getting water in your trunk when raining? it's because whenever it rains and i use the car, my trunk compartment gets wet. i can't seem to trace the source of the water. my best theory here is the water from the power antenna or water coming from the drainage vent just below the power antenna. it gets wet in that area only. i had my mudguards removed and i suspect water splashing from the tires enters the drainage vent.
    have you guys experienced this before?
    yup, friends of mine have experienced that also. check your tail lights also kasi baka di na siya naka-seal ng mabuti.
    Feb 2003
    meron water drain hose yung power antenna, check if it's connected properly sa exit way ng tubig. normally it won't leak any water yan pag di nagagalaw except kung nabangga ka na at pinalitan yan.
    agree with ssaloon, check your tail lights.
    Feb 2003
    baka naman nagangga dati yung auto mo?
    Dec 2003
    yup... double check mo yung taillights dati ganyan din yung civic ko eh.. dun dumadaloy yung water....
    Jul 2004
    baka nga yung tail lights or yung antenna mo yung dinadaanan. was your car bumped at the trunk part before?
    Jul 2003
    Also check the rear bumper support/clip, the rubber gasket might be defective. That is No.17 in the drawing below:
    <img src=http://www.slhondaparts.com/images/PCI/13S041/012/9.jpg>
    Jul 2003
    the drawing:
    <img src="http://www.slhondaparts.com/images/PCI/13S041/012/9.jpg">
    Jul 2003
    OK I'll just attach the pic:
Help on my Civic SiR!!!
