Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
    Apr 2005
    mga pre, this morning i had this problem. when i tried to start my car, may redondo pero ayaw tumuloy. turned it off. stepped on the gas pedal 3x. re-start. rpm went to 800 initially down to 600 down to zero. namatay. stepped on the gas pedal again 3x. re-start. tumuloy na mag-start. any ideas what could be the problem? i also had this problem yesterday. ---1998 corolla xe 1.3carb (163T kms)
    baka lunod.
    When was your last tune up? Check your fuel filter and ignition wires.
    use the choke switch.
    pull it then turn on the ignition,
    kapag umi-start, i-tono mo na lang using the choke switch.
    Apr 2005
    sorry guys but i'm still a newbie regarding cars since i just got mine last year. just changed oil & sparkplugs, & sprayed 3m carb cleaner, this month. naglagay din ako whiz octane booster & fuel injector cleaner on my last full tank with petron extra unleaded. changed air cleaner & fuel filter last feb.
    Jan 2004
    could be many things. maybe you should give your car a full tune-up. try to check yung ignition timing. or could be in the ignition wires. but to be sure, treat your car a tune-up.
    Quote Originally Posted by maverick34
    Nagpa engine wash ka ba lately? If yes, check kung nabasa spark plugs.
    Apr 2005
    Quote Originally Posted by falken
    yes. after changing the plugs last august 1. pinacheck ko pa nga using torque wrench kung mahigpit kabit plugs kasi d-i-y lang change.
    Aug 2003
    what's a choke switch? diba diesel lang meron nun? (sorry for the n00b question)
    Apr 2005
    the only thing i did differently yesterday: after washing and waxing the car, pinag-overflow ko windshield washer water reservoir para lumabas yung dumi sa loob. yun lang.
hard starting corolla
