Results 1 to 10 of 12
December 27th, 2005 10:37 AM #1Guys help me naman yesterday byahe ako sa NLEX ang sarap dahil maganda ang daan. Here is my problem at 110 or 100kph pagminor ako tapak sa preno nanginginig kung manibel. ano kaya problem.
- Dec 2005
- 10
December 27th, 2005 10:42 AM #2baka pudpod na brake pads mo... as you said.. "nanginig yun manibela when you stepped on the brake" .
December 27th, 2005 12:26 PM #3
kung imbalance lang tire kaya nanginginig, pag apak mo ng 120Kph pataas mawawala ang nginig. pero delikado ito.
December 27th, 2005 12:35 PM #4
OT: buti ka pa 110 ung sa barkada ko hanggang 60 lang nanginginig na. hehehe
December 27th, 2005 12:43 PM #5
check the following:
- wheel balancing
- tie rod ends
- collapsed tire belts
-try mo din baka maluwag ang mga lug nuts mo.
when braking:
-worn out pads
-uneven wear on the disc/drum facing.
my bet is the tie rod ends. have it replaced immediately. baka dyan ka pa madisgrasya.
December 27th, 2005 01:21 PM #6
Originally Posted by ian_rex
December 27th, 2005 02:27 PM #7
pwede pa rin pero pagawa mo agad. just hope na balancing lang ang problema. check your tires also baka kalbo na yan e delikado yan. kung tie rod naman e pagawa mo agad.
- May 2005
- 277
December 27th, 2005 02:43 PM #8pagawa mo na hindi naman lahat ang nabanggit eh sira.hindi naman kamahalan.Sa experience ko ,safe naman. huwag lang lampas 80kph at hindi mo na patatagalin.
December 27th, 2005 03:46 PM #9
sige mabuti ng safe, rather than ma-accident dahil sa kapabayaan. salamat po sa lahat ng information. learned me a lot.
saludo ako sanyo. mabuhay tsikot.com
- Oct 2005
- 317
December 27th, 2005 09:00 PM #10unahin mo na yung wheel balance sa experience ko gulong lang yan! ingat ka bro!
