Results 1 to 10 of 13
- Feb 2004
- 35
March 17th, 2004 10:15 PM #1Good day mga peeps. Tanong ko lang ilang pounds ang kayang i-operate ng door lock actuator? Kaya ba nito makaoperate ng pinto if ever i-tap ko yung "trigger" ng door to open via the door lock actuator? Thanks.
March 17th, 2004 11:04 PM #2
It could help your door ajar a bit. You would also need to customize the striker to work with it.
- Feb 2004
- 35
March 17th, 2004 11:50 PM #3Thank you sir ungas, ano yung striker? Is it the same as the trigger or the actual mechanism that opens the door? Ang project ko kse ngayon ay i-shave yung door handles, that's why i'm asking kung pwede yung door lock actuators. Ok lang kung i-customize. Thanks uli.
March 18th, 2004 02:27 PM #4
Not a good idea to shave it off, you would need atleast need it if in any case the customized door acutator fails.
Kung gusto mo ng fully opened doors, let the door acutator work for the srtiker or door trigger then add hydraulic shafts used on hoods to open the doors wide.
March 18th, 2004 04:12 PM #5
If you plan to shave, leave the tailgate door handle intact. Para you have a back up plan in case the electrics fail on you.
- Feb 2004
- 35
- Feb 2004
- 35
March 18th, 2004 11:37 PM #8Originally posted by OTEP
March 18th, 2004 11:43 PM #9
itutuloy mo na ba talaga yan?naka bili ka na ng ano ba tawag dun?...POPPER?
- Feb 2004
- 35
March 18th, 2004 11:47 PM #10Originally posted by Ungas
Thanks sir ungasLast edited by LowRev; March 18th, 2004 at 11:51 PM.
