Results 1 to 10 of 17
    Sep 2019
    Good day mga sirs, maginquire lang po ako. just bought a 2009 Honda City AT. So far no problem naman sa takbo. I'm starting to do maintenance na din as per the service manual.
    ask ko lang kasi dalawang tao na po nagsabi sakin na need ko din palitan differential fluid oil nito, pero base sa service manual, wala naman po specs or scheduled maintenance sa differential.
    also, i'm planning to diy atf change, ask ko lang if CVT na po ba ang transmission assy ng model na to? as per manual, atf z1 ang recommended and base sa nababasa ko dito, z1 was already replaced by dw-1 fluid. ok lang ba gamitin to?
    btw so far smooth shifting pa yung gears as of the moment, gusto ko lang manigurado na tamang fluid and mailalagay
    The 2009-2013 City/Jazz has the traditional torque converter 5-speed AT tranny. You have to use the Honda ATF DW1 fluid and change it every 40k km. You will need around 4L for the usual drip and refill method. Since FWD yung kotse, wala sya differential only the transaxle but this is part of the tranny assembly.
    Sep 2019
    ayun, salamat sa confirmation sir
    Aug 2017
    Galing-galing 👌
    Quote Originally Posted by SidCoronel View Post
    Galing-galing 👌
    parang medyo sensitive ang honda AT in that it requires OEM honda atf. ang toyota or mitsubishi as long as within specs maski 3rd party brand ok lang..
    naalala ko yun 2006 FD ang ginamit ko royal purple ATF buti na lang di nagloko.
    Better be safe than sorry. Di rin naman kamahalan yung Honda OEM fluids.
    good point.
Differential Fluid and Transmission fluid on Honda City
