Results 1 to 8 of 8
    Jan 2004
    Guys,
    Ano ba tamang distancia ng intake at exhaust side ng valve sa PH16 engine ?
    MBB
    Jan 2004
    tappets clearance pala
    Jan 2004
    is PH16 have the same specs as the D16z6 honda engine ?
    iba yata yung sa d16z6..i assume na d16y8 ang makina nyan since na mention mo na ph16..
    kinuha ko lang sa service manual to: for d16y8-
    VALVETRAIN
    standard(new) service limit
    valve clearance(cold) IN 0.18 - 0.22(0.007-0.009) ------------
    EX 0.23 - 0.27(0.009-0.011) ------------
    valve stem O.D IN 5.48 - 5.49(0.2157-0.2161) 5.45(0.2146)
    EX 5.45 - 5.46(0.2146-0.2150) 5.42(0.2134)
    stem to guide IN 0.02 - 0.05(0.001-0.002) 0.08(0.003)
    clearance EX 0.05- 0.08(0.002-0.003) 0.11(0.004)
    HTH
    Jan 2004
    thanks benchph1, so yung d16y8 pala ang equiv ng PH16 natin dito ?
    yep tinawag lang syang PH16 kasi dito sya inassemble...pero ang general name nya talaga ay d16.
    heres a more detailed explanation:
    d- single cam engine
    16- engine displacement
    y5, y7, y8 - engine type
    Jan 2004
    Benchph1,
    i've read na a d16y8 engine is VTEC already, yung PH16 inde namn diba ?
    teka teka what im referring to is the PH16 -d16y8 (vtec) of the civic ek vti (96-00)..medyo naguluhan nga ako eh..nung tiningnan ko sa service manual yung eg civic , d16z6 daw ung makina...pero may vtec. eh ung mga esi dito sa pinas lahat walang vtec eh
PH16 valve clearance
