Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Apr 2006
    tanong lang po.
    kapag yung rpm ko umaabot ng 3000rpm.
    medyo umuusok na po yung tambutso ko (kulay puti).
    kahit naka-idle siya umuusok po?
    normal lang po ba yun? kung di normal ano po kaya ang problema?
    (96 vtec matic)
    tnx
    Quote Originally Posted by kabuke0
    tanong lang po.
    (96 vtec matic)
    tnx
    When have you last had your engine tuned up? Have you checked your engine oil level, is it decreasing? You can have a competent mechanic check your sparkplugs for their condition.
    Apr 2006
    kapapalit ko lang ng engine oil. if ever sa sparkplug...are there any symptoms?
    Feb 2006
    white smoke = water
    black smoke = oil
    check valve seals .
    Apr 2006
    yes it is a white smoke.
    is it coming from rain? car wash water?
    where is the valve seals? (is that engine valve?)
    Try these websites:
    http://www.ngksparkplugs.com/techinf...q/faqread2.asp
    and
    http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
    Aug 2005
    -tuned up
    -check your spark plugs kung ano condition ng sunog
    don mo malalamn kung valve seals or lose compression
    Nov 2003
    smoke is mostly a bad sign when it comes to an engines health
    Aug 2005
    valve seals really give up in a certain age.
    mga bro, sa akin naman e pag first start ko sa morning or malamig panahon e me puting usok lumalabas but after mge 5-10 minutes nawawala,,ano kaya yun? is that a normal moist or something wrong na with my engine and need inspection?tnks
umuusok ang tambutso ko?
