Results 1 to 8 of 8
    pag sa umaga or pag nai-park ko ng matagal. madali syang mag-start kaso kailangan ko mag-rev ng rev para di mamatay. pag binitawan ko gas pedal namamatay. kung baga kailangan pag-initin muna. dami ko nang napagdalhan na shop pero walang makaayos eh. kahit suki kong mekaniko di nya naayos. napa-tune up ko na din. ganun pa din. ano kayang problema? it's not a big deal naman kaso lang pag iniisip ko medyo aksaya sa gas tsaka di ako makaalis kagad pag nagmamadali. i'm driving a corolla ae92 nga pala. thanks.
    bump.
    cud be a case of dirty IM or TB!
    wats IM and TB?
    Aug 2003
    had that problem before. mahina din ba hatak ng oto mo? if that's so, spark plugs lang yan. palinis mo lang o papalitan mo ng bago. kung ok naman spark plugs mo, palinis air filter at carburetor. adjusting the idling and air/fuel mix also helps.
    i think it's not as simple as a dirty spark plug, air filter, or sometimes, even carburators... i also had that problem before, and my friend also... i don't know what the mechanic did, but at that time, i had a top overhaul because it is already needed. when i got my car back, the problem was already gone.
    not that i'm saying that the engine needs a top overhaul. what i'm just trying to point out is that sometimes, tune-up can't fix the problem... as what was already mentioned earlier.
    Nov 2003
    it could be a case of faulty body grounds. or it could be that you need a new carb. bring it to a shop that can diagnose it properly
    your fuel filter may need replacement...
    nag replace ka ba ng air filter nung last tune up, baka kelangan na din...
cold start problem
