Results 1 to 5 of 5
August 9th, 2006 07:24 PM #1
First symptom. Nakabukas pa pinto pag start ko nag-lock mga pinto.
Second, papasok ako sa auto pag disarm ko, naglock ulit. Tried it again, ganun na naman.
Third minsan ayaw gumana nung locking switch sa loob ng auto. Pag gumagana, minsan nagloloko. Pag unlock, maglo-lock ulit agad.
Fourth, habang umaandar naririnig mo yung tunog ng lock/unlock pero di naman umaangat o bumaba yung lock.
At the time, naka open yung master lock ng power windows, meaning kahit sino pwede buksan. Sinubukan ko i-lock so only the driver can unlock it, hindi nagloloko. Binalik ko sa open yung lock ng bintana, medyo nagloloko pa rin pero not as bad as nung una.
Ano kaya problema? Grounded kaya or something?
August 9th, 2006 09:14 PM #2
Have the alarm checked bro. Minsan yun ang suspect eh. Happened to me before.
August 10th, 2006 09:54 AM #3
Naku wag naman sana... Although di pa sya nagloloko since kahapon.
Sana wag na! hehehe
August 15th, 2006 08:47 AM #4
Symptom yan na isa sa mga machina ng lock is madali na bumigay i just treplaced my motor on the driver's side it cost 300php kasi each door may sariling motor. we had the same symptoms akala ko programing lang ng alarm pero hindi pala. Nakakatakot nga because there is a risk that you will get locked out with the car running and no spare key. I suggest if you have no time yet to have it repaired disable mo muna ung alarm may sariling fuse yan. If grounded madali lang ayusin yan babaklasin lang ung main module tapos titingnan ung wiring pagtagal talaga eventually mangyayari yan
August 15th, 2006 08:57 AM #5
baka yung battery ng sasakyan mo medyo alanganin na. ganyan kasi nangyari sa amin one time papauwi galing tagaytay. akyat- baba yung mga door locks...parang may poltergiest
Tesla Philippines
