Results 1 to 10 of 10
May 5th, 2008 01:50 PM #1
help! just found out about it over the weekend. may kalawang na ang ilalim ng ek ko. anong maganda gawin? bakbakin na ba kasi medyo bulok na iyong affected part?!
- Jan 2008
- 380
May 6th, 2008 08:40 AM #2Bakbakin mo na yan bago dumating ang tag-ulan
. Mas maganda sana kung angat yung sasakyan. KUng meron mang butas, may DIY na paraan naman dyan.
Screw driver(pang-tusok), angle grinder, wire brush, disc grinder, 80 to 120 grit sandpaper, rust converter, paint brush, Zinc chromate primer, chassis black or bosny/RJ aerosol undercoat, masking tape, dyaryo, duct tape(pantakip pag di natapos agad), scrap GI sheet, rivet, epoxy, sealant...
May 7th, 2008 12:39 AM #3
^tama ka bro. napatingin ko na sa latero at kailangan pro na gumawa. di ko kaya idaan sa diy as much as i want to
kaya ngayon canvass ako ng shop na mapapagkatiwalaan around las pinas or alabang para mapagawa na bago dumating ang wet season ng tuluyan
btw, aside form ziebart, what are the names of the other shops w/c specialize in rustproofing/undercoating?Last edited by baludoy; May 7th, 2008 at 01:15 AM.
May 7th, 2008 06:48 AM #4
kailangan tangagalin lahat ang kinalawang, mas maganda kung ipa-cut mo nalang tapos patakpan.
May 7th, 2008 07:48 AM #5
^that's the plan nga bro. kaya 'di na kaya ng diy powers ko bro
problema nga lang, ilang araw din ang downtime ng kotse.
but i suppose it's all for the best na din
- Jan 2008
- 380
May 7th, 2008 08:38 AM #6Use spot welding as much as possible, di tumatagal yung alambre, at dapat talaga malinis at na-grind o na-brush na mabuti ang mga kalawang bago pinturahan. See to it personally, pa-vacumm mo if needed. Pwede palagyan mo muna ito ng rust converter.
IMO, mas ok if you will apply anti-rust primer first, like Zinc Chromate, before mo patungan ng undercoat o chassis black.
- Feb 2008
- 577
- Jan 2008
- 380
May 9th, 2008 09:40 AM #8Yung kay utol, binili nya lang sa hardware, mga about 200 petot ata per liter, lahat ng mga pumopormang kalawang sa flooring at pang ilalim ng van nya, timbog na, meron pang natira. Ewan lang kung meron aerosol nito sa Concorde.
Okey na to sa underchassis at inner parts ng sasakyan na medyo me kalawang, prepare lang mabuti ang surface bago i-recoat.
- Feb 2008
- 577
- Jan 2008
- 380
May 9th, 2008 12:31 PM #10Rust converter yang Turco. Zinc Chromate actually is a Top Quality anti-corrosion agent that is added to paints/coatings. It was developed by Ford Motors in the early 20th century. It is intensively utilized in US Military vehicles and civilian aircrafts.
But due to health hazard, the use of Zinc Chromate is regulated now in the US.
The Filipino based manufacturer of Anzhal, has products with Zinc Chromate, see
http://www.centurychemicals.com/results.asp
Yes, Anzhal Urethane Primer has it.
Boysen has them also. If possible, for DIY, using only brush, select the 'epoxy paint' preparation of zinc chromate.
Tesla Philippines
