Results 1 to 10 of 33
    Ask ko lang mga sir, san po ba ung speedyfix? kaya po ba nila ang overheat? Kasi po ung car ko po nag-overheat sya kapag traffic at nakaon ang aircon pero habang tumatakbo at naka-on ang aircon ok naman po sya. Ano po kaya problem nun...sensya na po a...ilang beses na rin ako naloko sa banawe...purkit girl ako inaabuso ako...hehehehe...nissan 1995 po ung car ko...tnx!
    May 2007
    Quote Originally Posted by cherryfin View Post
    it's along Shaw Blvd., Mandaluyong City, katabi ng Puregold and Goldilock's.
    Jun 2006
    Speedyfix is in Shaw Blvd. Across Red Ribbon and almost beside Pure Gold. They have a big signage. Tel no 717-4202 look for Migs.
    Kung di ka nagoverheat pagoff ang aircon, most likely aircon fan ang prob.
    The reason it heats up during traffic is the AC fan can not push enough air to cool your engine. When running, you have enough airflow to keep your car cool.
    Simple test you can so is open the hood. Start the car and let it idle till it reaches normal operating temp. 1 fan should start up. Turn on AC, the other fan should also run. That, 2nd fan is your AC fan. If it does not run or is slower than your other fan, you found the culprit.
    meron po ba ditong taga bulacan o merong may alam na shop sa bulacan na magaling mag overhaul ng civic engine?
    Salamat...
car problems. Need help! please!
