Results 1 to 10 of 11
November 14th, 2006 08:10 AM #1
I just noticed this today. Nagboboil yung water dun sa lalagyan ng tubig sa loob ng engine bay. Is this normal?
Car's engine is off. Corolla 95 gli.
Zombie
- Aug 2006
- 728
November 14th, 2006 09:01 AM #2can you give us more details?
how long have you run the car? after turning off the engine, you popped the hood and you open the reservoir cap and the water/coolant was boiling (think kettle in a stove) or was steam pouring out?
did your temp gauge say you were overheating?
November 14th, 2006 10:26 AM #3
Only 20 mins drive from qc to pasig.
i turned the engine off then i heard some gurgling. Then i popped the hood and the water was boiling where you put the water in the plastic container, Not steam. i didnt open the radiator cap because it seemed really hot.
Didnt notice if the temp guage showed overheating. i'll check on my way back home later.
Tsikot Member Rank 3
- Dec 2002
- 551
November 14th, 2006 10:39 AM #4its not normal. Better check if your 2 fans are working they might be the cause of the overheating
November 14th, 2006 11:06 AM #5
drive again and look at your temp gauge. the gurgling could be water coming from the radiator going into the reservoir.
November 14th, 2006 01:26 PM #6
happened to me before 15 minutes drive lang from my place to shagrila edsa, i heard gurgling in my engine compartment and when i opened the hood, the collant reservoir was boiling.
when i got home, i discovered wala na halos coolant/tubig yung radiator, nagli-leak pala sa drain plug, i simply tighten the plug and added coolant and water and okay na sya.
- Jun 2006
- 138
November 14th, 2006 01:39 PM #7Yung nangyari sa akin medyo bubbly yung reservoir pero hindi yung talagang bubbles na parang nagpapakulo ng tubig. Napansin ko lang after a long trip.
November 14th, 2006 01:40 PM #8
nangyari na sa tsikot ko yan dati, aux fan ang culprit.
have your auxillary fan motors checked na lang.
upod na ang carbon ng motor nyan kaya hindi na normal ang ikot ng fan.
November 14th, 2006 01:59 PM #9
prelude to overheating yan, the kind na titirik ang kotse mo in heavy traffic.
Check the following:
1. Auxilliary Fans, see that they are working,
2. Coolant. Make sure na may coolant ka, not just plain water.
3. If your car is old, baka yung water pump, nag stuck up na. . .
4. Check for leaks in the radiator if you notice na panay lagay mo ng tubig.
November 15th, 2006 08:30 AM #10
