Results 1 to 10 of 16
- Nov 2016
- 15
November 26th, 2016 03:54 AM #1hi maam /sir , i would just like to ask if ano po kaya problem sa battery ng sasakyan namen. na discharged sya then when tried the kadyot/tulak jumpstart. then na revive, so we let the car on for a little while and a bit of a stroll and let the alternator do its work for recharging. a day after nung naipark na pag start namen discharged nanaman. we have been repeating this kadyot start method but it just dies again. revived and battery and after a day discharged nanaman. what could be the main cause of this mishap. please help. any ideas, thanks
- Aug 2012
- 2,767
- Aug 2012
- 2,767
November 26th, 2016 06:56 AM #3My car battery can last 2 months if car is unused. But I make sure it is 100% fully charged by using car battery charger before I travel abroad.
Sent from my D5833 using Tapatalk
- Oct 2006
- 6,091
- 53,883
November 26th, 2016 09:35 AM #5as red asks, how old is your battery, po?
i am very familiar with your scenario. we used to do it when we were young and poor-ish, because we had difficulty buying a brand new battery.
in our experience, the battery was simply old and dying. it would hold a strong charge for a short time only. after a few minutes running the engine, we could actually re-start the engine using the starter. but after 30 minutes or so, there was only enough juice in her that we could still push-start the car, but not activate the starter..
have the battery checked at the battery shop, po. sometimes, one of the six cells may be the culprit, but in our experience, once one starts to go, the rest will follow "soon".
another possibility, is that you have a short or a big parasitic leak somewhere. an auto electrician will be able to help you here. but check out your battery, first.
- Apr 2009
- 551
November 26th, 2016 09:52 AM #6How old is your battery? and what Brand? its an indicator of your cars electrical. if you have a premium battery and its
more than 2 years , its time to replace. but if its just 1 year maybe its your electrical system. Delikado na yan darating ang panahon kahit jumpstart hindi na yan aandar. just like dr. d said pa check sa auto electrician.
November 26th, 2016 10:56 AM #8
The only batteries that don't decay are the dry charged batteries, once you activate with sulfuric acid, it slowly matures to death. Factors that accelerate death of the batteries include shock and vibration, heat and deep cycling. Otherwise if the battery dies sooner than the expected life, maybe the charging rate is insufficient in comparison to the current draw or the battery is not big enough for the vehicle
- 53,883
November 26th, 2016 11:52 AM #9prolonged periods of battery discharge or undercharge, also hasten battery death.
- Nov 2016
- 15
November 26th, 2016 12:53 PM #105 years old mitsubishi adventure and an outlast brand battery 1 yr and 3 mos old. thanks for all the replies.
feeling ko parasitic load so bka maipacheck nlg sa servitek pa multimeter/voltmeter.
Tesla Philippines
