Results 1 to 10 of 27
September 2nd, 2004 04:04 PM #1
has anybody herd of or tried this pinoy invention, Khaos super turbo charger? 6500 with instalation na daw and installs in 20 mins lang. ok kaya ito? here's the link www.khaos.com.ph
- 10,620
September 2nd, 2004 04:32 PM #2here we go again.
mukhang dati na yan pinalitan lang yung pangalan na Khaos.
also meron yan sa F150 ng bayaw ko, wala naman effect.
also sana naman alisin na nila yung turbo super charger sa name, kasi baka naman akala nga mga "iba" instant HP gain sila at magkarera sa kalye.
and unless ma satisfy si Yebo dun pa lang ako maniniwala he..he
September 2nd, 2004 05:05 PM #3
here we go again and again and again! notorious na ba ako sa pagka-skeptic at ako agad nasa-isip mo nyahahahaha!
i hope i do not get misunderstood by people here, i just ask questions because it's the only way to protect ourselves from scams and "inventions" that only rob us of our hard earned money.
tignan ko ang link, malay mo this is one of those one-in-a-million that does what it claims.
time out muna, magbabalik...
September 2nd, 2004 05:21 PM #4
dati na to binigyan lang ng new name, super turbo charger by mr planas. it leans your air/fuel mixture by adding a small air filter on the intake manifold. since the added air does not pass through the O2 sensor then the fuel management system will not be able to detect it and thus the a/f ratio will lean out. on carburated engines the air filter inlet port is added after the carb, on efi it is after the O2 sensor.
imho, it will save gas and also lower CO, but the claim that it will lead to more power output is something that needs to be tested. if you lean out the air/fuel ratio what normally happens is that the power output will go down, not up.
if you go for fuel economy, then i think it's ok (that is, i think for now until i find out more about this product!). you would not want to put this on your engine if you like to overtake or carry heavy loads often, kakapusin ka sa arankada.
so it's part true and part scam. imho lang ha.
- Aug 2004
- 163
September 2nd, 2004 05:28 PM #5I checked the website...and found this , I quote:
". It minimizes other pollutants like hydro carbon, carbon
dioxide, oxide of nitrogen to less harmful level. Since
KSTC achieve efficient combustion it can prolong the life
span of the engine, spark plug, mufflers, and engine oil."
Whenever claim for minimizing CO2 emission and efficient combustion is made, be very cautious...
CO2 is the normal product of combustion...in fact, you get more CO2 as combustion becomes more efficient... that's where the CARBON in the fuel goes.....
September 2nd, 2004 05:32 PM #6
kung ako lang bili na lang ako ng K&N, same effect. kung pwede CAI pa, sure ka pa na talagang lalakas engine mo. more power on the engine will also mean less fuel consumption if you drive it easy.
September 2nd, 2004 05:58 PM #7
ayos talaga sa tsikot!!!!! my bro-in-law saw the ad on a tabloid... and asked me kung ok. sa tingin ko nga parang pipe lang na nilagyan ng kung anong parang valves tapos binenta ng 6500.
so if its after the carb pwed kang maglagay ng small taiwan filter to the same effect din kaya?
- Apr 2004
- 653
September 2nd, 2004 06:42 PM #8KHAOS..rhymes with chaos..hmmm..chaotic na ang sitwasyon ng economya natin tapos me kumakalat pang P6500 gadget confusing people's weary minds..?!
this is too burdensome..hanap na lang tayo ng mura na epektibo pa..
September 2nd, 2004 06:53 PM #10
ser yebo, magtayo ka na nang testing consultancy for automotive aftermarket products.....hehehehe
tapos request lang, una mong i-test yung mga invention ni vee-val....hyukhyukhyukhyukhyuk...:bwahaha:
siguradong masaya yan.....:bwahaha::bwahaha::bwahaha:Last edited by 5Speed; September 2nd, 2004 at 06:59 PM.
Tesla Philippines
