Results 1 to 10 of 23
- Oct 2004
- 132
December 28th, 2004 12:00 PM #1Ngyon ko lang napansin umilaw sa panel ko ito (blue =D) everytime i turn on my headlights... is this related sa busted kong brake lights sa likod??? D ko mahanap manual ng sasakyan. Offline naman http://www.redpepperracing.com/techn...vic-FSM?page=1 kaya d ko masearch... kaya sa inyo na lang ako tatakbo.
FYI. Im running a Honda 97 civic vti.
December 28th, 2004 12:08 PM #3
Don't know about the Civic...
In Toyota's, it only lights up if your high beams are on.
In the old VW beetle, when your headlamps are on, the blue light is also on. And when you go to high beam, the blue light is brighter...
HTH
- Oct 2004
- 132
December 28th, 2004 12:12 PM #4Hindi ko po alam... This is really an embarassing moment kung nagkataong hi/low beam nga un...
- Dec 2004
- 41
December 28th, 2004 01:25 PM #5sa corolla xl ko laging naka on...ibig sabihin laging naka high beam ang headlight ko? kasi when i switch to low beam ung headlights naka turn off totally. May problem ba headlights ko o ung switch lang?
December 28th, 2004 01:49 PM #7
pull up para mawala yung high beam/blue light. and pull back again when using high beam or push forward for other cars.
di kaya nagagalit yung mga nakakasalubong mo nyan? :D
December 28th, 2004 01:59 PM #9
high beam indicator ng headlights yan. pag off then naka-low beam ang headlights. yung case naman ni nimra, baka busted na ang low beam mo, o kaya fuse.
December 28th, 2004 02:06 PM #10
sa mga honda light stalks, you can find it on the left side; if you want to activate the high beams just push the stalk forward ( provided that the lights are already in low beams )
maybe you forgot to bring the stalk backwards( this is to turn off the high beams) thats why when you turn your low beams, naka bright agad.
Tesla Philippines
