Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
    #21
    I have that FE in my sammy. Don't put it in the trunk. Install it where you can access it without getting out of the vehicle. Refillable po yun sa handyman may mounting bracket and meter pa siya.
    Nov 2006
    #22
    additional lang sa basic tools na iyong dadalhin,
    test light and most important thing ang safety googles for eye protection.
    Feb 2007
    #23
    ratchet and sockets #8, 10, deep 12, 14, 17, deep 21, univ joint, short extension bar
    flex rod, adjustable spanner, vise-grip, long nose pliers, work light
    cutter, flat and phillips screwdrivers, set of combination wrenches
    ewd, long g.i. pipe, wd-40, tire gauge, air compressor, tow cable, jumper cables
    gallon of distilled water, motor oil, rags, bulbs, a relay, vacuum hose, jack
    torque wrench, tie wire, assorted fuses, clips, screws, nuts, and washers
    #24
    Usually for long trips, I bring most of these. The big ones, i keep in the trunk.
    1. cable ties, various sizes
    2. wrenches 8 - 12
    3. 8" adjustable wrench
    4. philips and flat screwdrivers
    5. 1 liter extra engine oil and ATF, and some brake fluid
    6. extra fuses
    7. mech pliers, long nose pliers and wire cutter
    8. some spare wires and nuts and bolts
    9. 4 liters tap water and extra container
    10. lighter, can opener, extra shirt, shorts
    11. LED flashlight
    12. towing rope
    13. 2 ton jack and cross wrench
    14. basahan, 1 sachet of car shampoo
    15. jumper cables
    16. EWD, elect. air pum
    17. a bottle of betadine, some cotton and bandages
    Ano pa ba pdeng i-add?
    #25
    tyre wrench + 2ton jack
    screw driver + / -
    plier
    long nose
    vise grip
    fuse
    flashlight
    engine oil
    break fluid
    PS fluid
    4ltr water
    adjustable wrench
    nuts/bolts
    fanbelt
    tester
    mga abubot
    cable ties
    #26
    Up ko lang for Adventure to see.
    Feb 2006
    #27
    -toolkit na nilagay na ng casa, may kasama na first aid kit
    -calling card ng tow service (hoping they're still in business if i need to call them)
    -early warning device
    i'm planning to get the airpump w/ flashlight and pressure gauge in 1 na nakita ko sa ace hardware, may nakabili na ba nito? durable po ba? mabilis po ba mag-inflate ng tire?
    thanks
  8. #28
    basic tools for tire changing.(freebie)
    vice grip, cutter, basahan, small pliers
    and
    handy feather duster.. hehe
  9. #29
    hmmm... dapat pala bumili na ako isang heavy duty na tool box, ang liit ng tool compartment ng innova
    #30
    EWD
    long nose
    screw driver
    basahan ( some old underwear )
    grease
    wd40
    brake fluid
anong laman ng toolbox nyo?
