Results 1 to 9 of 9
- May 2005
- 66
February 5th, 2007 03:44 PM #1guys, meron bang problema kung ang nilagay na atf ay Caltex AllisonC4 instead of DexronII?
I availed the transtech service of Autotechnika last week pero ngayon ko lang napansin sa receipt na AllisonC4 ang ginamit na atf. I immediately called their SA and wala daw problem dapat yun.
I need your reactions on this. My ride is Toyota Corona 93.
TIA
Tsikot Member Rank 4
- Jun 2006
- 2,605
February 5th, 2007 05:35 PM #2Do you know which caltex atf it is, specifically which variant? Caltex has several ATFs.
http://www.chevronlubricants.com/wor...1/default1.asp
Caltex ATF-HD meets both Alison C4 and Dexron II
Caltex Texamatic 1322S also meets Alison C4 and Dexron III
same with Caltex Texamatic 1888 ND Texamatic 7045E
- May 2005
- 66
February 5th, 2007 05:45 PM #3they used caltex atf-hd.
if that's the case then I should not worry, right?
tia
- Jun 2006
- 2,605
February 5th, 2007 05:53 PM #4Your fine.
Here is the link to the product data sheet:
https://www.cbest.chevron.com/genera...PDS7693690.PDF
- May 2005
- 66
- Sep 2005
- 59
February 5th, 2007 06:53 PM #6Makisakay na rin po sa thread since same din ask ko but different atf.What if I use dextron III instead of Diamond SPII? Should I be safe? Car is 95 Galant. Thanks!
- Jun 2006
- 2,605
February 5th, 2007 08:09 PM #7
- May 2010
- 1
May 29th, 2010 01:04 AM #8I want to know the characteristics of Caltex Dexron II.
Can you provide me this information?
Thanks.
- May 2010
- 1
May 29th, 2010 01:28 AM #9I want to know the characteristics of Caltex Dexron II.
Thanks.
