Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Feb 2005
    Hi! i'm kinda new here and am desprately in need of help. My problem with my car is that it's like being pressed up and down from the front left corner of the hood and from the right corner of the trunk alternately!!! what could be the problem here? I had the front shocks checked and the mechanic dicovered that the left shock mounting was defective and had it replaced with a new one. But when I test the car for a drive there was still this "dribbling" although it became lesser it seems, it still makes me uncomfortable. I'd appreciate it if you could help me out on this, Thanks in advance, God Bless!
    check your tire pressure too. it may be too high than the recommended psi.
    Feb 2005
    Thanks ssaloon, all 4 wheels are 29psi and their sizes are 185x70x13 is the 29psi within the recommended psi?
    29 at 13? baka mataas pa... imho, average ata nyan dapat is 25 psi.
    Feb 2005
    thanks happy_gilmore i'll try your 25 psi!
    Jul 2003
    How about a VAN? im using 33psi all tires at cold. ok lang ba?
    what van? dun sa starex reco nila 40 sa front then 65 sa rear.
    check dapat mabuti yan dribbling....baka ma double dribble ka dyan..turnover yun. hehe dyok!
    Feb 2005
    or maybe the tire has uneven wear? thek if its oblong? thats why its dribbling
    Dec 2003
    oo nga baka may oblong lang na tire check mo..
    haha..
    Feb 2005
    big possibility na defective ang tires.. lalo na kung recap lang.. kung brand new naman ang tires ipa camber mo baka nakabaliko ang settings..
Help! my car is dribling!!!!
