Results 1 to 10 of 14
    Jan 2008
    good pm mga sir ask ko lang kung san ba maganda magpagawa ng busina? nawala na lang kasi basta e. nung pinatignan ko kasi di daw nila kaya kasi gagalawin ung airbag dahil dun daw nagkaroon ng loose connection. ano ba maganda gawin dito? hirap mg byahe ng wala busina e. ask ko na din magkano aabutin ng pagawa nito. tnx!
    what car, year, model sir? na scan ho ba yung airbag or naka ilaw ba yung airbag light, baka simple horn ckt lang.
    Well, at least your mechanic stated that they are not capable of fixing it (rather than trying to fix it then breaking something).
    Have it checked by a service center that is more capable of handling those kind of specialized jobs (like Autotechnika or your casa).
    Jan 2008
    salamat po sa mga nag reply...
    to t2erns: corolla 98 gli po. di na scan ung airbag kasi di na naman nila ginalaw e pero naka ilaw ung airbag light nya.
    to mazdamazda: oo buti nga ganun sila. nag inquire na din ako sa toyota sabi dalhin ko na lang dun para ma tignan nila kung ano naging problema.
    Dec 2007
    Nangyari na rin sa akin yan although wala akong airbag.
    Test mo muna yung fuses mo. Pumutok na ba yung fuse mo para sa busina? Buy a bunch of replacement fuses. Kapag pinalitan mo yung fuse tapos bumusina ka ulit, napuputol na naman ba siya? If that's the case, the horn itself is busted/shorted out and has to be replaced.
    Mura lang ang busina. I didn't want the tinny stock Jazz horn so I got Stebel Magnum twintones for PhP900.
    If your horn's fuse is fine you have to look for some other culprit.
    Jun 2005
    gayahin nyo na lang po yung ibang mga jeep. yung busina nila naka kabit na sa may kambyo.
airbag/busina problem
