Results 1 to 8 of 8
- Nov 2004
- 45
November 14th, 2018 06:23 PM #1Guys pa help naman
I can hear some kinda rattling sound after i release the gas pedal at speeds greater than 80 kph . Kapag mabagal naman walang ganun.
If i press again the gas pedal accelerator the sound goes away and it come back after i release it then after a while mawawala ung abnormal sound.
My ride is a gasoline innova automatic (more than 12 years old)
Maraming salamat
November 14th, 2018 07:10 PM #2
November 14th, 2018 07:14 PM #3
where do you hear the sound? on the floor? on the dash? did you passby a construction site?
November 14th, 2018 08:31 PM #4
Could be the propeller shaft or the joints
November 15th, 2018 08:17 AM #5
Post an audio recording of the noise and as best you can, determine where it is orignating from.
Just spit-balling, on my previous Civic, when you hear some rattling sound when the gas pedal was released, this usually means that the belt auto-tensioner has worn down. These auto-belt tensioners have a damper (similar to a shock absorber) that is designed to stop the belt from flapping around. It wears out over time and when it does, it becomes more like an un-damped spring, causing the belt to briefly oscillate when the accelerator pedal is released.
This is just one possible source of the noise. Yours may differ.
November 15th, 2018 09:21 AM #6
Baka tumatama lang yun exhaust or manifold cover.
- 53,883
November 15th, 2018 09:52 AM #7
- May 2011
- 481
