Results 1 to 10 of 12
Tsikot Member Rank 3
- Oct 2003
- 734
February 2nd, 2004 02:25 PM #1ask ko lang , ano ba ang advisable na tire height sa isang 17 inch na mags given our present road conditions. totoo pala yun sabi ng isang poster na pag nalubak masisira gulong lalo na yun manipis na 40 series. i am using a 215 50 R17 ksi nalubak ako na deform. at totoo ba na pag mas heigher yun height na gulong mas less prone na sya sa deformation pag nalubak? anong gulong bibilhin ko? thnx --------------------------------------------------------------------------------
February 2nd, 2004 02:35 PM #2
IMO, driving on our local dilapidated roads should not have low profile tires. Minimum ratio aspect should be 70 and above.
If I were you, I'd sell the low ratio and get the bulging offroad tires. A 265/70R15 sounds safe enough to run on EDSA.
- Oct 2003
- 734
February 2nd, 2004 03:42 PM #3bakit yun ginagamit sa rallye racing na evolution 225 50 R17 ang gamit nakita ko sa megamall eh puro rough roads dinadaanan nun galing pa ata ng disyerto yun or anywhere where there are no roads? ok lng sana yun specs na binigay mo kaso lng hindi naman SUV dala ko eh, spacewagon gamit ko.
February 2nd, 2004 03:52 PM #4
Iba po ang rallye spec tires, thicker sidewalls and tread plies. Plus different model of tires are used on each given terrain. The one you saw on display was sporting another set of tires not used for competition. Just for display and showing purposes only.
Street tires does not have the ability to protect itself from sudden bumps and potholes. Their ability is just to keep the air in and provide grips on dry or wet surfaces. Given the potholed streets in our metropolis, it would be much better to use 60-70 ratio for your ordinary city driving ang highway drive. To protect your invested money on those mag wheels.
February 2nd, 2004 03:55 PM #5
dapat hinay lang pag naka 17" rim ka or talagang sira yung tires and rims mo. that's why im also changing my rims to something smaller baka mag 16 ako with 55 or 60 series. masyadong kawawa yung gulong dito sa atin. bad trip lang.
- Oct 2003
- 734
February 2nd, 2004 04:17 PM #6i understand now pang showroom lang pala yun akala ko kasi yun na yun ginagamit nila sa pag nag rarallye sa disyerto. bad trip talaga ganun pala yun, ang tulin ko kasi magpatakbo eh. huli ko na kasi nalaman na these tires are not desgned to run on rough roads much more potholes asar talaga! sira na rin kaya mags ko pag ganun na lubak ko at paano ko malalaman kng nasira? another thing naidrive ko car ko na flat about 3 kms sira na kaya mags ko pag ganun? thnx talaga
February 2nd, 2004 05:01 PM #7
about your mags..
if the bare-naked eyes couldn't see kung na-bingkong na ito
or na-deform..
kapag nagpa-balance ka ng tires..
dun mo malalaman kung nasira ba yung mags mo o hindi.
kung ganon, sana makuha pa sa press..
basta sa reputable shop ka pumunta para sure ka na sira talaga kung mags mo kaya ipe-press..
some tire shops like Miller's sa may QC..
say that your mags needs to be pressed kahit di naman sira.
February 3rd, 2004 09:48 AM #8Street tires does not have the ability to protect itself from sudden bumps and potholes. Their ability is just to keep the air in and provide grips on dry or wet surfaces. Given the potholed streets in our metropolis, it would be much better to use 60-70 ratio for your ordinary city driving ang highway drive. To protect your invested money on those mag wheels.
Mag 17 ka if you're not passing roads like EDSA or streets that are rough...
I already find it hard since my car is small and has only 145/70R12 series and the rear is 155/80 series
Tsikot Member Rank 5
- Nov 2003
- 3,848
February 3rd, 2004 10:58 AM #9i've been using 205/40/17 tires for over 2 years and wala pa ako naging problema with bengkong or any other tire problems. it really is in the way you drive and pick the route you take.
also, depende kung maganda suspension mo. if you have a good one that is able to absorb most of the bumps then this should minimize the chances of damaging your wheels and tires.
btw, evo's have 225/45 tires.
February 4th, 2004 01:49 AM #10
oo nga po... napapanood ko sa tv sa rally low profile mga gulong nila... ano kaya yun?? special tires? not for sale? hehehe... btw... bakit po gulong ng 4x4 ko... nakasulat 10lt r15 yata...??? from pajero... walang... lapad/series/rim??? ndi ko tuloy alam kung ano bibilhin ko kung sakali... stock yun ng tonka pajero eh... btw... hats the largest sige na kakasya sa non-highered na pajero with no problem at all? iniisip ko din.. magkakaproblema ba kung iba size ng spare tire ko sa gamit na tire???
Tesla Philippines
