Results 1 to 7 of 7
Threaded View
October 27th, 2013 01:18 PM #5
The NEW Classic MOKE - is back - and it is more free than ever
With Chery mechanicals.
http://www.mokeinternational.com/ima...e-brochure.pdf
GENERAL
Model Year: 2013
Engine: SQR371F
Transmission: 5MT
Body Type: Cabriolet
Top Speed: 110 km/h
POWERTRAIN + TRANSMISSION
Engine Type: SQR371F
Displacement: 993m
Aspirated: Naturally aspirated
Cylinder Arrangement: L
Cylinder Number: 4
Valve of each cylinder: 3
Compression ratio: 10
Valve timing mechanism: DOHC
Number of strokes: 4
Power (PS/KW * rpm): 50/6000
Torque (Nm * rpm): 93/3800-4500
Fuel type: Gas
Fuel lab: 93#
Fuel supply: MPI
Cylinder head material: Al
Cylinder block material: Steel
Emission Standard: Euro 4
Transmission type: 5MT
Transmission housing material: Al
CHASSIS
Drive Model: FWD
Suspension Front: Independent MacPherson strut front suspension
Suspension Rear: Longitude trailing arm dependent suspension
Subframe Front: Metal plate pressing & weld
Spring Type Front/Rear: Coiled Spring
Steering System: HPS
Brakes Front: Disc
Brakes Rear: Drum Type
Parking Brake Type: Hand Brake
Brakes Power-Assisted: Vacuum booster
Wheels Trim: Steel
Tire Size: 175/65R13
Tesla Philippines
