Results 1 to 6 of 6
- Dec 2008
- 74
October 11th, 2012 12:57 PM #1Hello po mga bossing,
Ask ko lang po itong problem ko regarding po minsan kapag ini-start ko yung kotse ay nagmo-motorboat sound yung starter ko. Para pong tuloy-tuloy siya na umaandar na ang remedy na ginagawa ko ay dini-disconnect ko kaagad yung battery, dahil dun umiinit ng husto yung starter. Then hindi na mag-s-start.
Ang isang advise po sa akin ay tingnan ko daw po yung ignition switch ko. Pinatingnan ko na po yung starter ko at yung alternator, ok naman po daw pati yung battery. Bago po yung battery.
Paano po ba tini-test yung ignition switch(susian). makukuha po ba yun sa pag-spray lang ng WD40? Ano po ba ang dapat kong gawin?
Minsanan lang pong mangyari iyon kaya nga lang hassle po kapag nasa kalagitnaan kayo ng trapik at biglang magluluko iyong starter.
Louie
Magkano nga po pala itong ignition switch Nissan 93 kung ito nga po ang nagluluko?Last edited by louiellopez; October 11th, 2012 at 12:58 PM. Reason: emoticons
- Feb 2012
- 70
- Dec 2008
- 74
October 11th, 2012 04:28 PM #3oem ba yun? anong naging problema nung sa iyo? pareho ba nung symptoms sa akin?
- 53,883
October 12th, 2012 06:32 PM #4minsan lang ba, o madalas, o palagi? does the stuck starter interfere with the flywheel or not?
a good auto electrician should be able to find out if it is the switch or not. testing lang yan using simple meter.
the starter switch assembly is two parts in one: the key and tumbler mechanism, and the electrical contacts. WD40 will just fix tumbler sticking, but the electrical contacts are sealed and not reachable.
but the problem is, the symptoms may be intermittent. electrical intermittents are hard to troubleshoot.
the starter assembly is also in two parts: the starter armature, and the starter solenoid. both are not difficult to fix.
- Feb 2012
- 70
October 15th, 2012 05:43 PM #5buksan mu ung ilalim ng susian, or tignan mo. . bka sobrang luma na ung ignition switch mo. . makikita mo nman e, ung parang sunog na, delikado yan, palitan muna bro.
- Dec 2008
- 74
October 15th, 2012 11:56 PM #6Minsanan lang mangyari, akala ko nga nung una ay nasira na naman dahil kapapalit lang nung solenoid anyway may problema nga nung pinatingnan ko, naka loose contact na yung 2 carbon. Pero nung ginamit ko sa kalagitnaan ng trapik, bigla akong namatayan at nung inistart ko na ay nagluko na naman. I don't think at that time it interfere with the flywheel,dahil minsan tumuloy namang mag-start nung kotse kaya lang yung nag-stuck up yung starter.
