Results 11 to 19 of 19
October 4th, 2015 10:15 PM #11
- Apr 2010
- 97
October 5th, 2015 10:27 AM #12ok sir, thank you po uli. pa change atf ko muna this week and see kung wala na yung problema hopefully
- Aug 2014
- 26
October 6th, 2015 09:33 AM #13Transmission Speed Sensor yan, ganyan yung problem ko dati intermittent, try mo muna pascan to check for codes. Minsan ok tas pagsusumpong pag pahinto kana and aarangkada ayaw magshift sa segunda, tas restart mo ok na ulit.
- Apr 2010
- 97
October 6th, 2015 11:53 AM #14sige po sir pa scan ko po ung speed sensor, ganon nga po kung pahinto ka tapos aarangkada ka na from 1st gear, hanggang doon nalang kahit e rev mo pa na halos umabot na sa 3k rpm ayaw mag segunda. sa ngayon di ko muna gamitin hanggang mapa change atf ko at ma check ung sensor. salamat po balitaan ko nalang kayo pag napa service ko na
- Oct 2015
- 4
October 7th, 2015 03:14 PM #15sir,
Kung tama po ang pag kakaintindi ko,na encounter ko n yan issue mo. Try mo sir mag hananap ng VSS (vehicle speed Sensor), that will solve it. Kasi po sakin, from normal speed, it can go up to 4th gear kaya lang pag na traffic na, Nag hihigh rev lang, ung tipong ayaw kumagat sa 2nd gear, until I need to turn off the engine, wait for 25 secs, then its normal again.
Try to ask a friend who has the same unit that you have. Kasi ung sakin, dumresto na ako ng Nissan Shaw, I had a video recording of what is the actual incident and they immediately stated its the VSS. I ask them what if hnd un, kasi brandnew ung bibilhin ko hnd namn un papalitan kung mali ang diagnose nila. They understood my sentiment, luckily, pinahiram nila ako... I tested it and drove it going to baguio. I did not encounter the said trouble. I had purchased the said part and it caused me around 7.5K
Try mo muna hiram sa tropa mo.
October 7th, 2015 03:23 PM #16
Instead of a basic ATF change, try having ATF dialysis done. There's a thread on that in the forums. Last time my friend had his done at Exalta in Banawe.
- Mar 2015
- 11
October 21st, 2015 12:29 PM #17Hi friends,
Sorry to hi jack thread. what are the signs that a exalta has transmission problems? I had the radiator overhauled and shifting is Ok.
Sometimes though I can hear a rattle sound coming from somewhere in the front. I'm not sure if it's a transmission problem.
Alex
- May 2016
- 7
May 18th, 2016 03:01 PM #18Im planning to buy fo a Nissan Sentra 1.3 gx 2005 model kc dun lng po swak ang budget ko, okay po b ang model n toh ang s fuel consumption matipid po b sya? and s parts po madali lng po b mkahanap ng replacement if ever masira? 180k lng po kc budget ko help nman po...
- Jun 2016
- 5
June 5th, 2016 12:20 AM #19Medyo underpowered po since 1.3 lang yong engine, pero kung relax driving lang naman kayo all the time, then swak na swak po sa inyo ito. Fuel consumption, depende po sa right foot nyo kung madalas kayo napapadiin sa gas pedal, mas malakas sa gas. Sa parts in terms of engine bay, exterior, and interiors, walang problema po yan. Marami yan sa mga surplus shops.
Tesla Philippines
