Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Feb 2012
    paki silip din kung gumagalaw ung bearing. . dapat yan walang alog. . mura lang ang bearing at belt bro. palitan muna. . sori to say, . ung mekaniko mo is sablay, . ang totoong mrunong na mekaniko, alam dpat nila gagawin dyan once cnbe mu ung concern mu, . kht pa hndi tumunog yan sa harapan nila. .
    Aug 2012
    ung compressor bearing is only P400 while tensioner bearing is only P100. you can replace the tensioner bearing but the compressor but bearing you must bring it to ac technician . kaya nothing to worry dahil minor lang yan......
    Apr 2009
    *TS: minsan may nakasabay ako magpaayos sa talyer na ganito problem, squeaking yung belt nung big body corolla. i saw the mechanic sprayed WD-40 on the belt, then the squeaking stopped. i don't know if it had bad effects on the belt, pero parang stop-gap procedure lang yung ginawa nya and it worked.
    i once had the same problem with my ride nung nagpalit ako ng belt. brought it back to the shop, then they re-adjusted the tensioner bearing. masyado daw masikip yung unang setting. after the adjustment wala na yung tunog.
    Aug 2013
    same issue before, pinacheck ko sabi bearing ng alternator (makunat na), pinalitan, meron parin pero hindi na madalas pag inistart nalang, pinahigpitan ung belt, meron patin, palit belt na, un nawala, baka lang makatulong, sa naggagawa ng aircon ko pinaayos,
    had this experience before na my parang uma-alingitngit sa fanbelt. had the pulleys checked, bearings greased and tensioners adjusted pero meron pa din. pinunasan yung belts and applied a little grease and voila, ayos na. madumi lang pala. hehe
    Apr 2024
    Quote Originally Posted by nuebe View Post
    hindi ba basa ng langis?
    Kapag nabasa Ng langis ano dapat Gawin para mag normal mga sir any good advice or suggestion
    Nov 2019
    Quote Originally Posted by Rjmar View Post
    Pa check nyo po sa mechanic, baka need lang linisan at patuyuin if bago pa yung belt.
    If mataas na mileage since na replacean, much better if palitan nalang baka nag degrade na yung quality ng belt after nabasa ng langis.
    Mura lang yung belt at labor for replacement.
    Jan 2009
    What car/engine and what are the issues or symptoms?
    Accessory belts are kinda tough and a little water or oil is not going to significantly affect it. If it's making a noise, find out where it's coming from (as in, which pulley) and check for alignment, wear, or damage. Check also the belt itself, including the tensioner if it's still providing enough tension and dampening. Check the condition of all the idler pulleys, including the one on the tensioner.
    Check also the alternator pulley. When worn out, the internal one-way clutch mechanism (if equipped) will start to slip and give off loud chirping noises.
please help: squeaking fan belt when turning a/c on
