Results 21 to 30 of 30
- Jul 2012
- 60
September 4th, 2012 11:29 AM #21
- Jul 2012
- 60
September 4th, 2012 11:34 AM #22ako depende sa kulay ng oil ako ng papachange oil..kng mejo maitim na maxado ngpapa change oil ako after 6th month. city driving lng naman ako every day. pinapacheck ko lng kotse kng may complaint ako like performance issue such as brake, and the like.. so far ok pa pang ilalim ko..walang kalampag.. complaint ko lng ung performance kng umiinit na pero later ko na paayos kng may pera na para isahan nlng na gastos.
Ako ksi ng base lng ako sa previous experience sa nissan ko..kinucompare ko ung nissan ko ngaun at ung dati ko.
- Nov 2004
- 73
September 6th, 2012 05:52 PM #23sir allier, yung sa picture ba yung b13 mo ? ok ah . stock lang sya ? ano year ng b13 ?
- Oct 2012
- 2
October 17th, 2012 01:52 AM #24mga sir ask ko lng din may sentra eccs 1992 model bigay ng utol ko tinry ko syang gamitin naka OFF ung aircon maganda hawak, pero nung nag AC n ako pag nagrerevolution n ako para pong nabubulunan n parang mamatay. ano po kaya defect nya, then ung AC din po mahina n wala ng lamig malaki po ba magagastos ko?..help nman po please thnk u..
- Jul 2012
- 60
November 3rd, 2012 11:56 PM #25just clean your iacv...it is connected to your throttle body where violet colored harness attached.
- Jul 2012
- 60
November 19th, 2012 05:22 PM #26Problem solved! The reason of poor engine performance is due to oil leaks inside the distributor. The oil seal inside the distributor already replace and it solves the problem.
- Nov 2004
- 73
November 23rd, 2012 10:17 PM #27ok sir criz, buti naman na solve na siya,. kaso nung binunot yung distributor mo, may o ring pa sya., sana napalitan mo na rin yun. sabagay, baka sa loob lang ng dist gumawa yung mekaniko. di ba naluto yung ign coil at igniter mo sa loob ng distributor ?sorry, medyo matagal na, b14 sa iyo? kung b13 , nasa labas ang coil yata, pero yung b14, nasa loob yung coil sa distributor. parang ganun na alala ko
- Jul 2012
- 60
November 24th, 2012 03:19 PM #28
- Nov 2004
- 73
November 26th, 2012 05:42 AM #29yes sir. ok na yan. kaya dalawa yung pinalitan,palagay ko yung o ring sa labas ng distributor yung isa. sa loob kasi ng distributor, oil seal lang ang nandun. ayos na yan. tatagal na uli.
- Jul 2012
- 60
November 28th, 2012 01:13 AM #30
Tesla Philippines
