Results 1 to 10 of 21
- Jul 2014
- 145
January 19th, 2018 06:44 PM #1Hi mga sir, post natin dito mga DIY natin sa navara. Share knowledge po.. Thanks
Sent from my XT1650 using Tapatalk
- Dec 2007
- 186
January 21st, 2019 06:03 PM #2I updraded my factory reverse camera to a higher definition after market -Sinairyu
and installation is here...
NISSAN NAVARA NP3 factory reverse camera upgrade - Album on Imgur
- Dec 2007
- 186
February 22nd, 2019 02:56 PM #3my LED Tail light upgrade
remove the tail lights with two 10mm bolts. lift the original tail light carefully with a plastic prying tool and hold it firmly.
there are 6 wires on the connector
connect and solder the 6ohm load resistor (i made it from two 12ohm 10W ceramic resistors connected, soldered in parallel and insulated the connections with a ceramic sealant) to the signal lights wires and insulate with electrical tape. 6 ohms is required to retain the normal flash rate. no load resistor, flash rate is faster.
test the LED lights before final installation.
finally, install the new LED tail light assembly
i have more pics at imgur. photos here are limited by moderator.
- Dec 2007
- 186
February 24th, 2019 11:25 PM #4also added THe V5 NAVARA grille..
Navara logo changes color between white/amber when turning lights/applying brakes. patong lang and i didn't get rid of the original grille in case mag sawa. connection of the controller wires took some time.
at side view, bumukol mukha ng navara!
i'll be back with the ADAS rear view mirror upgrade and the 3D 360deg AVM add on when it comes.
- Nov 2009
- 3,503
February 25th, 2019 12:03 AM #5I don't D23 but i do D40, somebody could confirm if tailgate damper install is worthit-no frills plug-in install?
I bet we have the same heavy tailgate that needs dampening, atleast the D23 is now lockable.
Concorde SUS.TEC Easy Down Tailgate Damper Navara 2 6-2 15 (1 Pc) | Lazada PH
February 25th, 2019 09:38 AM #6
- Dec 2007
- 186
February 25th, 2019 12:02 PM #7i have a neighbor two houses away. the dad has the D40 and the son the D23. the dad had installed dampers on his tail gate while the son didn't. cguro mas mabigat ang D40 but i'm not sure.
i also have ordered from amazon the lifter for the hood and already in my possession. it is chinese i think because there are clips which could easily come out. di ko muna ininstall because of quality concerns. malaysia has better dampers.
- Dec 2007
- 186
- Dec 2007
- 186
February 28th, 2019 12:50 PM #9shipped by seller and awaiting delivery..i'll feedback soon once installed.
- Dec 2007
- 186
March 2nd, 2019 12:36 PM #10received the ADAS rearview mirror today... the bracket is crucial. hopefully it should match with the factory adaptor as guaranteed by the seller. just awaiting for the above item to come and the bumper sensors para isang baklasan lang at sabay2 na pag install lahat.
the original factory bracket below, i hope the mirror bracket matches to the adaptor (right).
