Results 1 to 10 of 11
- Nov 2008
- 6
July 1st, 2009 12:37 PM #1Hi guys! i just bought a 98 cefiro. It went thru a general checkup at Nissan and they told me that i would have to replace all 6 the ignition coils. Do I really have to do this or can i just replace those which are failing? Can anyone recommend a good car shop that can give me a second opinion and do this service including tune up? thanks a lot
July 1st, 2009 12:50 PM #2
SPEEDLAB http://www.speedlab.com.ph/
SPEEDYFIX http://www.speedyfixph.com/
Check their websites for address and contact info.
July 1st, 2009 12:54 PM #3
Get a second opinion. My brother was "recommended" for a service job at Honda Shaw which would have costed nearly P30,000 (parts & labor) because of a minor overheat problem. At Speedyfix, the source of the problem was found to be a leaky by-pass hose and a failing radiator fan motor. Total bill at Speedyfix was just over P2K including labor.
July 1st, 2009 08:50 PM #4
This is the first time i hear of the DI coils needing replacement... Why did they diagnose such? With the Cefiro i'd be more worried about leaking gaskets actually.
For the tune-up, you can go to other shops like Speedyfix, Autotechnika, Speedlab... Just buy the proper plugs as recommended by the manual. FYI, the stock NGK double platinum plugs (PFR something) on the Cefiro are good for 80,000kms to 100,000kms.
Try to use 95 octane fuel as well since the Cefiro VQ20 is picky when it comes to fuel (Petron XCS is what i'd recommend).Last edited by vinj; July 1st, 2009 at 08:53 PM.
- Feb 2008
- 325
July 1st, 2009 09:58 PM #5may nararamdaman k naman bang sira sa kotse mo? You said that you went to Nissan for general check-up lang. Kung wala ka namang nararamdamang sira ay better get second or third opinion before replacing the ignition coils.
- Nov 2008
- 6
July 2nd, 2009 01:49 PM #6Thanks. I will try to go to speedyfix this weekend. maybe they can give me an honest opinion. Nissan quoted me 41k for the job. They also quoted me 30k for suspension works but when i brought it to cruven it cost me only P4.4k. grabe no! I'm sure speedyfix can do better. thanks ghosthunter!
- Nov 2008
- 6
July 2nd, 2009 01:59 PM #7thanks vinj. started using Petron XCS. I'm really surprised why they want to change all the coils. they recommended though to change the valve cover gasket and all bypass hoses even if there was no leak. Will drop by speedyfix this weekend to have the car checked. thanks again
July 2nd, 2009 02:00 PM #8
- Nov 2008
- 6
July 2nd, 2009 02:02 PM #9
July 2nd, 2009 02:03 PM #10
