Results 1 to 2 of 2
- Aug 2017
- 8
August 13th, 2017 03:16 PM #1
pag start ko ng car ok na ok walang problema. pero pag uminit na sya about 15 mins. pag ni revolusyon ko biglang babagsak ung menor from 600rpm to 100rpm nanginginig makina. pero most of the time nakaka recover ung RPM babalik ulit sa 600idle. pag minomonitor ko nabagsak ung idle sa 100 minsan namamatay di na nakaka recover. "PERO" pag may a/c na di na sya nag bagsak ng 100rpm from 600 to 400rpm na di na namamatay. kakaibang sakit po ito rare... :-( ano gagawin ko. nissan serena qrvr
Sent from my SM-A710F using Tsikot Forums mobile app
- 53,883
August 15th, 2017 10:37 PM #2if your engine is like my '97 sentra, you might try opening up the air bleed screw by a fraction of a turn. "if nothing happens, turn the screw back in", as it's probably not the problem."
when you turn on the aircon, the idle up circuit comes into play, increasing your idling rpm.
good luck, po.
