Results 1 to 10 of 32
- May 2015
- 16
May 26th, 2015 01:58 PM #1I will consider this, thanks so much Sir. The problem only is I have to tow the car since I can't use it to go there as it is... It dies every 5-10mins.
Nag-iistart naman cya Sir kaso namamatay after 10mins or so...
May 26th, 2015 02:12 PM #2
ok....
you have to determine if its electrical or fuel related.
have you checked na din the high tension wires?
ok....
- May 2015
- 16
May 26th, 2015 02:19 PM #3I did a manual check on the high tension wires, unplugging each of it while the engine is running to see if the engine would run and sounds like it's out of time, so far as the manual test goes it went good. Do you have any ways and means of testing it Sir?
I did a manual check on the high tension wires, unplugging each of it while the engine is running to see if the engine would run and sound like it's out of time, so far as the manual test goes it went good. Do you have any ways and means of testing it Sir?
May 26th, 2015 04:02 PM #4
If it dies every five to ten, that's a heat-related issue... and could very well be electrical... might want to check the new coil you bought and see if it's okay.
I had a similar issue and went through several coils... only to find out the ECU was shorting everything out.
Best to take it in and have all the wiring checked.
- May 2015
- 16
June 30th, 2015 04:17 AM #6
On my B14 which I owned several years ago, a similar issue was fixed by cleaning the fuel injectors...
- Mar 2014
- 901
July 9th, 2015 11:19 AM #7
Tesla Philippines
