Results 21 to 30 of 32
October 29th, 2009 09:44 AM #21
- Oct 2009
- 1
October 31st, 2009 04:44 PM #22
- Sep 2009
- 4
November 5th, 2009 08:22 AM #23WARNING: Don't do this if you have any [SIZE=6]DOUBTS![/SIZE]
Hi guyz!...i converted my local series3 ecu to jdm ecu(at last for 1month of non stop internet?)...hehe!...HOW?
NEEDED:
Personal Computer or laptop
*Printer with some bond papers
Electrician(OPTIONAL)
1.Go to JWT website.Look for [COLOR=blue ! important][COLOR=blue ! important]Nissan[/COLOR][/COLOR] ecu identification core.
2.Look for the same year model of your car.(GA16dne ecu not on the list)
3.Choose what ecu you want.(GA16-SR20)"i choose the SR20 engine even i have a ga16dne engine."
4.Look for the year model ECU PINOUT DIAGRAM.(ex.95 sentra ecu pinout diagram)
5.Now look and examine your harness for open or shorted wiring,and mostly the SAME CONNECTOR that your going to use.
6.Compare your ecu pinout(91-94 sentra)..(97+ jdm sentra ecu have different connector)....to the one that you choose.
7.Most nissan ecu pinout are the same.Be sure to look for the COMPLETE ecu pinout or you will miss some wirings.
8.Relocate the wiring that you notice are NOT in the position on your choosen ecu pinout.
9.All done...? recheck for short or open harness.(i download service manual on www.nissanhelp.com for sentra electrical,maintenance,mechanical,etc..this is a very helpfull website.Sentra electrical service manual have all the test needed.(ex.ecu power supply,output check test.etc....)
10.All Good and your car REVs and RUN again.GOODLUCK and GODBLESS!:cheers:
- Nov 2009
- 1
November 6th, 2009 01:44 AM #24Sir, ano nga po ung website? Sira din kasi ECU ng Sentra Ko. Series III 96 A/T. Hirap maghanap ng ECU, meron ka man makita, grabe ang presyo. para ka nang bumili ng surplus engine.
- Oct 2009
- 17
November 11th, 2009 05:32 AM #26
November 14th, 2009 09:02 PM #27
November 27th, 2009 04:25 PM #28
Mga sir, nag japan surplus na lang ako kasi talagang walang makuwaan ng comp. box... napansin ko lang, parang ang lakas nya na mag consume ng gas... di ko pa nachecheck yung mismong figures pero dati naman hindi siya ganito katakaw... dun po kaya yun sa ECU or dahil lang di siya napaandar for almost 2 months?
November 27th, 2009 08:14 PM #29
i also have nissan sentra SS3 with busted ECU
what i did was i bought a surplus ga15 carb and have an engine swap.
now my sentra is home, running fine... i already knew that i will have a problem in finding a surplus ecu with no guarantee it will run fine in years to come. also, i hate it when my sensors got damage.. what a bum
di ko naman masyadong problema ang e10 kasi kapag naphase out na ang pure gasoline i still have another option which is the lpg conversion
total damage= 15k for the engine
+ 5k for labor
almost 20k din *still have some rewiring to be done, hope it will not be pocket buster
nawala din ang mystery idle dive-bombing and jerking of my sentra...
December 1st, 2009 09:43 PM #30
