Results 1 to 7 of 7
- Mar 2012
- 16
September 14th, 2012 03:23 PM #1good day po.. i have encountered a problem with my clutch yesterday.. while i was parking, i noticed that my reverse gear can no longer be released and my clutch pedal seemed to be very soft to step at.. i turned the engine off and opened the hood.. i noticed that the fluid in the reservoir was below the minimum level.. then i saw the transmission is having leak..
the leak comes from the encircled area with the green circle..
what seems to be the problem and what will be the possible cheapest solution?
thanks guys..
i don't own the picture, i just got it online..
whoever owns it, my sincerest apologies..
September 14th, 2012 08:20 PM #2
September 14th, 2012 09:23 PM #3
a replacement repair kit will cost you P200-300 while a replacement assembly runs at around P600+. I suggest just get a replacement assembly as a whole if you can't afford an original repair kit/assembly. (Original repair kit is more than P1500 while original assembly is....hay!)
- Mar 2012
- 16
September 14th, 2012 11:18 PM #4how about the price of the clutch release bearing, pressure plate, and clutch disc sir?
September 15th, 2012 09:56 PM #5
- Nov 2004
- 73
September 16th, 2012 07:39 AM #6sir cost ng replacement parts, hindi naman magkakalayo, magtanong ka sa 2 stores, ok na yun. tama ka nga, habang nakababa na, silipin mo na rin ang parts na yun, lalo na kung di ka naman diy, at ibabayad mo rin lang ang trabaho. pero gaya ng sabi mo, ,di mo pa naman naibaba, repair kit or assy muna nung slave cyl bihin mo.
- Mar 2012
- 16
September 16th, 2012 03:48 PM #7
Tesla Philippines
