Results 1 to 4 of 4
- Jul 2011
- 3
July 19th, 2011 01:52 AM #1Are there locally available shocks that are similar to a Float XMR for Moto racing, here's the specs:
FEATURES/TECHNOLOGIES
- Ultra-lightweight (1.1 lbs * 10.25")- Velocity Sensitive Damping Control- Samurai Sealing System (SSS)- Self-adjust Air Negative Spring- Infinite Progressive Spring Rate- Internal Floating Piston (IFP)
ADJUSTMENTS
- Infinitely adjustable air spring- Air Volume Adjust (AVA) system- Wide-range rebound
Pwede kaya yung Monroe Air Shock? Ano specs nito, I can't find any dimensions sa net.
- Jun 2011
- 181
July 19th, 2011 03:55 PM #2
- Jul 2011
- 3
July 20th, 2011 02:28 AM #3I tried calling Monroe, pero wala daw sila available ngayon, and if I were to have it air freight it would cost 10x more!
We're actually building the third solar car and it needs an alternative shocks similar to a Fox XMR that is available locally. The shocks should be 10inches eye to eye.
Sige I'll try KYB and Rancho. Thanks for the heads up.
- Jun 2011
- 181
July 20th, 2011 12:35 PM #4solar car? nice, goodluck sir sa shocks, sana mahanap mo na and eventually mabili para makaandar na yung project mo.
Tesla Philippines
