Results 1 to 2 of 2
    Sep 2017
    This dual-color headlight bulb is perfect for driving in any bad weather. It has yellow (3000K) and white (6500K) color, provides a bright, comfortable and safe driving environment in any situation. Besides, you can switch the color rapidly by turning on or turning off the light.
    Its special features you must want to know:
    The latest dual color light in one LED headlamp(3000K Yellow & 6500K White), color change initiates once power switched.
    High/Low beam(H4/H13): high beam with golden light, low beam with white light.
    Single beam: first start with white light, turn off and start again with golden light.
    Superior optic control on road for optimal beam pattern to see the road condition clearly.
    0.1S quick start, allow a great distance for you to see and be seen in all weather conditions.
    And how to choose the led color temperature for driving? The Best color temperature for night driving is 6000K ~ 6500K, because this range of color temperature is most closely resemble sunlight, in which human eyes can see best. The Best color temperature for bad climate is 3000K. Yellow light is suitable for bad climate because it can cut through air moisture as compared to white light. It is perfect for conditions involving fog, snow, sleet, rain and storms thus it is the best HID color for visibility.
    Jun 2011
    Quote Originally Posted by Polo Tim View Post
    Is this the oem or mercedez benz vehicles?
    Do u have actual output with lux or lumens meter...
Why Do We Choose NOVSIGHT LED HEADLIGHT LIGHT BULBS DUAL COLOR WHITE & YELLOW 40W 8000LM?
