Results 1 to 4 of 4
    Jul 2011
    Hi,
    I just bought a pre-owned Mitsubishi Adventure and I dont have any idea about the right tire pressure for Mitsu Advi.. Hope you can help me out here.
    thanks.
    usually sir may sticker sa driver side door dun nakalagay ang preferred tire pressure sa ride niyo ewan ko lang kung stock pa rin yung gulong niyo pero usually di masyado nalalayo dun sa nakalagay sa sticker.
    Sa revo ang ginawa ko dun e 28psi sa harap, 30 psi sa likod. Preference mo na rin siguro yun. Ako minsan nag 33psi ako sa lahat e, pakiramdaman na lang kung comfortable ka sa ride mo.
    HTH
    Feb 2005
    32 lahat ang hangin ko. Pwede ring 30psi lahat para di matagtag
    Quote Originally Posted by car.pilot View Post
    Hi,
    thanks.
    same as the left? heh heh.
    but seriously, most auv pressures start at 28 psi. and if you put in 10% more, which is a safe allowance, that'd be about 31 psi. i'd say you have a choice on how comfortable (or how tagtag) you want to be.
    what i do is see what the manual or driver's pillar sticker recommends, then add 10% more. today, i'm on 34 psi.
    and i regularly see my thread wear pattern, to see if i am under- or over-inflating.
    oh! and i look at the maximum psi the tire allows (it's on the tire side wall).. just in case..
Right tire pressure
