Results 1 to 7 of 7
    Jun 2012
    pansin ko sa EL ko, hirap humila pag tama ang timing. chineck ng mekaniko gamit ung timing light. tama ang timing. pero hirap humila, kailangan laging madiin sa gas. kaya siguro malakas sa gas, 10 km/liter average. inadvance ko, wala namang tope, ganda humila. konting tapak sumisibat na. di ko pa pansin ang konsumo di pa ulit kasi ako lumalayo. ok lang ba to, na advance ung timing ko kung hindi naman tumotope?
    hindi kasi perfect timing sa timing belt mo
    Jun 2012
    ibig sabihin me gagalawin din sa timing belt ko?
    ganito yan eh kung replacement timing belt nilagay mo tiyak na hindi matitiming ng perfect yan sa crankshaft at camshaft. mag aadvance or retard ng 2 or 3 teeth sa timig belt depende sa pag install ng timing belt, 3 teeth malayo masyado
    i think what he is saying, is that the timing gears inside the engine have first to be adjusted correctly by the mechanic working on the engine. this is usually adjusted only once in a long while, as when replacing timing belts or chains. if this adjustment is done incorrectly, then there is no way anyone can adjust external timing on that engine, which is what you are attempting to do.. also, it can result in (if it hasn't yet) engine damage..
    btw, 10 km/li isn't all bad..
    Jun 2011
    Quote Originally Posted by leonzerimar View Post
    Ok yan basta madali naman i-start. Try to adjust the accelerator cable. Higpitan mo o luwagan, tingnan mo kung saan maganda hatak.
    Jun 2012
    Quote Originally Posted by perrydel View Post
    hinigpitan na ang cable, tune up, retiming. sumigla ng konti ang takbo nya. but still makupad, inoobertakean ako ng mga bastos na jeepney driver, hindi ako umaabot pag sabay kaming umarangkada! tsk tsk. to make matters worse, malakas sa gas. 145 km round trip bulacan-manila, ubos ang P800.00 ko! mga 9.14 km/liter, masakit sa bulsa, saklolo! or else mapipilitan ako na mag- kia pride ulit. mabagal man, mabagal din maubos ang gas kahit heavy traffic sa manila, hindi bumababa sa P14 km/liter...
questions about ignition timing
