Results 1 to 3 of 3
January 22nd, 2011 08:09 PM #1
Mga sir ang problem ng 2003 Advie (Grand Sport) ko ay may pumapasok na tubig sa loob, under ng dashboard kapag naglilinis ako ng sasakyan.
Sabi ng iba barado yung plenum drain, sabi naman ng iba need daw baklasin yung dashboard para makita yung problem. Sa labas nanggagaling ang tubig so bakit kailangan baklasin ang dashboard?
Tulong naman po kung paano linisin yung Plenum drain at kung ano itsura non.
Maraming salamat.
January 22nd, 2011 08:20 PM #2
the dashboard is behind the firewall. the source of your water intrusion while washing is possibly coming from the fresh air inlet for the airconditioning or from a rust hole in the cowl just below the cowl grille. the other possibility is a detached windshield from improper service procedure such as jacking the car with a garage jack on one corner of the front of the car. this causes the frame to twist (so does the windshield frame) and the butyl tape that was used to install the windshield has detached from either the windshield or the frame. try just pouring water around the suspected area sparingly. you might consider using scent or non permanent dye to confirm the origin of the leak
- Nov 2014
- 1
November 10th, 2014 08:57 PM #3I often see that the Bathroom sinks may become clogged with hair, soap ,etc which can cause stoppage of water on one place.Rooter service is very necessary in such situations when the drains get clogged and the sink is covered with the water.You should clean the entire pipe well so that your sinks will drain like new one.
