Results 1 to 5 of 5
- Mar 2010
- 9
April 28th, 2011 10:48 AM #1Hi to all,
please help me identifym bakit kapag ang pajero namin ay tumatakbo ng 40kph up is umuuging like may katabi kang motor na naka engine break. Please help and let me know.
Thanks
JOhn
- Jun 2004
- 476
April 28th, 2011 11:14 AM #3+1 baka wheel bearings yan or sa tires.
jack up the rig and put the trans in neutral - then turn one wheel at a time by hand with one hand on the body - if may na feel ka na ugong or slight grinding sound sa body wheel bearing ang culprit. If there's none most likely tires ang problem. hope this helps.
April 28th, 2011 11:33 AM #4
Check the front bearings and tires. Yung rear, if matic yan, dapat naka-N gear shift mo at umaandar makina bago mo galawin. Don't forget to put wedges while doing this check-us ha.
Fasten your seatbelt! Or else...Driven To Thrill!
- Mar 2010
- 9
April 28th, 2011 12:36 PM #5Well diko pa po nagawa yan, but i tried running on 50kph then shift to n since matic naman po still ma ugong padin. if bearing po that was my previous experienced po and ang tunog dapat eh hindi tuloy tuloy eto po sa harap nga ko po naririnig. Pero try ko padin po. Thanks
Tesla Philippines
