Results 1 to 10 of 44
- Nov 2002
- 208
July 25th, 2004 10:52 PM #1Gurus,
I noticed after my long trip back from the province, upon starting it in the morning malakas yun vibration ng engine and then tapakn mo gas mamamatay. After a few starts like this normal na sya. And during the whole day ok na sya. During 1st few starts in the morning. Nagstart lang talaga ito after my long trip back and forth to the province.
What could be the problem, dinala ko na to my 2 suking talyer, wala daw sila mkitang problema. Hindi raw mababa idling, oil/air filters were changed 2 months ago. Pinacheck ko rin engine support pero ok din daw. Sabi ng isa injection problem daw??? Pero I doubt it...
What could possibly be the problem. By the way 38th palang takbo ng ride ko. Thanks.....
- Nov 2002
- 208
July 25th, 2004 10:55 PM #2Pahabol lang glow plugs ko rin daw ok, all 4 were changed last december lang.
Tsikot Member Rank 3
- Dec 2002
- 551
July 25th, 2004 11:18 PM #3could your fuel be contaminated ? Like you had it filled up in an unfamiliar gas station ?
- Nov 2002
- 208
July 26th, 2004 07:42 PM #5johnart, pajerokid,
I usually fill up my ride with Shell only and usually I go to large gasoline stations.
If this is the culprit, can you suggests ways to solve the problem?
Thanks....
July 26th, 2004 07:52 PM #6
kung yun nga, just drain the tank and get a fresh batch.
not sure lang pre, pero you could also check the fuel filter and injectors. Not sure lang uli, pero a calibration may be in order.
July 26th, 2004 10:23 PM #7
looks like there is air in your fuel lines every morning. check mo check valve sa injection pump and sa may feed pump.
- Nov 2002
- 208
July 27th, 2004 11:55 PM #8ARB,
Pardon me for my ignorance, how will i know if there is air in the system?
DIY? lang ba sya?
Thanks
July 28th, 2004 04:00 AM #9
check mo yun wire that is connected sa water sensor under ng fuel filter. may times na may crack yun and air could sipped in.
July 28th, 2004 09:32 AM #10
usually pag may air ang fuel lines may misfiring feel like sa mga gas engines, especially on idle, but hardly felt on high rpm. the air will disappear after the car has run, unless my leak ang fuel lines then there will be air pockets in the fuel and misfiring or palyado feel can sometimes be experienced.
Tesla Philippines
