Results 1 to 5 of 5
- 14
April 22nd, 2013 11:58 AM #1My Lancer GLX 2007 problem right now is nanginginig and parang mamamatay sa primera if galing from full stop. What I'm doing right now is kadyutin ng konti konti yung gas para gumulong lang then full release yung clutch as nangyayari lang yun from full stop. The thing is makupad talaga ako pag traffic dahil di ko pwedeng ibaon yung gas if galing sa full stop. I also noticed na it happens when the engine has already warmed up. Pag malamig pa makina ayos naman. Really having hard time pag kailangan sumampa and need to temporarily stop.
Already replaced fuel filter but the same problem. Was initially suspecting for a clutch problem but sabi mukhang malakas pa yung clutch and pag clutch dapat existing yung problem either hot or cold yung makina
Appreciate advise.
Thanks!
April 22nd, 2013 12:09 PM #2
sir, hindi kaya sa driving style mo lang yan?
talagang manginginig ang auto and may tendency talaga mamatay engine pag aandar ka na from full stop, if hindi mo binigay ang sapat na apak ng gas sa level ng pag angat mo ng paa mo sa clutch.
about sa issue na nangyayari lang ito pag nasa operating temperature ang engine,
more likely naman sir mas mataas ang idle speed ng engine tuwing cold start, so kahit medyo bitawan talaga ang clutch kahit hindi gaano timplahin sa gas eh hindi manginginig and mamamatay ang engine kasi naaaccomodate ng higher idle speed yung sapat na gas for it to run smoothly pa.
my 2 cents.
- 14
April 22nd, 2013 12:51 PM #3Thanks for the advise sir. Unfortunately the problem is habang ginagasan mo e nanginginig wildly yung car na parang mamamatay. Para tumigil need to fully release the gas and hayaang gumulong konti yung kotse. But if you continue na ibaon yung gas while tinitimpla yung clutch, e mas lalong manginginig yung oto.
Aside from possible clutch problem, is timing issue a possibility?
Thanks!
April 22nd, 2013 12:53 PM #4
when was the last time you had the car tuned-up?
how is the condition of the fuel filter?
carb pa din yan diba? pa check mo din condition ng carb baka kailangan ng linis o overhaul.
- 14
Tesla Philippines
