Results 1 to 6 of 6
- Feb 2007
- 4
September 28th, 2011 11:23 PM #1Good day tsikoteers. We have a Montero Sport GLX, recently I busted the Left Reverse light of our Monty, ang problema pinapasok ngaun ng tubig ung loob ng ilaw, di tumalab ang mighty bond para mabuo ang nabasag. Gusto ko lang po nung rear fog na kagaya sa GTV at GLS SE para medyo kakaiba rin sa iba.
Does anyone know where could I buy the rear foglight na pareho sa GTV at GLS SE na Monty, Saan Casa or shop Nagiinstol at magkano ang magiging damage? Meron kaya sa El Dorado nitong item na to? nagkakabit din ba sila?
Sori mods if nagbuo pa ng thread badly needed lang. hoping for some help. Thanks in advance!
September 29th, 2011 02:37 PM #2
You can get it from any mitsu dealers, sa parts section, 2.8k. then you can have it installed there also. pero they will connect it to the park lights na as there is no ready connection for the rear fogs sa GLS/-V. Had installed it na kasi but still need to do minor modification on the rear fog relay supply to the ETACS ECU. Wala lang ako time kaya hindi ko pa matapos but will post the needed changes to have it activated thru the stack switch. You need to buy a relay (same relay type sa horn) and plug it in sa junction block (C215), yun wiring meron nakaabang sa D15 connector sa may rear bumper. Just need to tap on pin3. Yun sa EATCS meron isang wire, to follow pa ito...
- Sep 2010
- 16
August 29th, 2013 05:05 PM #3
- Sep 2010
- 16
December 19th, 2013 10:26 PM #5
sorry sir, now ko lang nakita ulit itong thread na ito. anyway, completed na yun setup as previously mentioned. yun nga lang, yun rear fog light is sabay mag ON with the front fog light kasi dun ko tap yun sa same source ng front fog relay, but still sa stack switch pa din. cannot do it na exactly sa OEM as ETACS program is different sa GLSV and GTV. If you want this setup, I can send it to your email sir...
- Sep 2010
- 16
February 7th, 2014 09:06 AM #6Uy! Nice! Baka pwede pa email na rin sir urbanhopper*gmail.com. I already had mine installed. Pero i had a switch installed para i can turn it off and on.
Thanks sir! Will be waiting for your email.
2005 Honda GD13 Jazz / 2010 Mitsubishi Montero GLS
Tesla Philippines
