Results 211 to 219 of 219
- Jun 2011
- 1,190
September 14th, 2024 01:31 PM #211
- Jan 2017
- 3
September 14th, 2024 08:58 PM #212
- 53,883
September 14th, 2024 11:25 PM #214
- Jan 2017
- 3
September 15th, 2024 10:55 AM #215I tested po na wala na lahat ng tools and others na magiingay. It looks coming from the tires. As in rinig talagay pag rough road. tnx
Possible kaya na may wheel alignment or camber alignment issue? Naging mas obvious ang sound several months after ko magpa alignment sa casa during maintenance. tnx
- 53,883
September 15th, 2024 11:16 AM #216hah!
check air pressure and alignment, again.
what's your current psi reading now, and what is the recommended psi?
and what tyres are you using? kasi, some tyres, especially off-road tyres, that are over-inflated, may be noisier, on highway roads.
does the noise have anything to do with your speed?
the sound of noisy tyres is characteristic, just as the sound of metal-to-metal, i.e., loose suspension or "lagutok", also are.Last edited by dr. d; September 15th, 2024 at 11:22 AM.
September 15th, 2024 11:21 AM #217
- Jun 2011
- 1,190
September 15th, 2024 02:59 PM #2182022 at 2018 ang sa amin. Hindi pa naman kailangan pa align. Straight pa ang takbo at even pa ang tire wear.
Possible after alignment may parts na na loosen ulit kung kulang sa higpit... tie rods, wheel nuts. Puwede pa check sa mga Goodyear Servitek or similar ships. Check ulit mga nuts ang bolts na nagalaw sa alignment.
Tesla Philippines
