Results 2,471 to 2,480 of 4928
December 5th, 2015 11:00 PM #2471
- Oct 2013
- 1,181
December 5th, 2015 11:02 PM #2472Nope, most of the firmwares are C based. Kailan na lang nag C++.
Nung una nga assembly language pa kami, kailangan mo pa bantayan ang stack mo kung mag interrupt ka.
Yang firmware na tinatawag, wala yan iba kundi ang compiled program na nilagay sa loob ng microcontroller.
Parang sarap pakingan, firmware. Program lang yan, pinasarap lang tawag.
- Mar 2015
- 65
December 5th, 2015 11:02 PM #2473
- Mar 2015
- 65
December 5th, 2015 11:06 PM #2475firmware or program are the same
- Oct 2013
- 1,181
December 5th, 2015 11:08 PM #2476Sabi ko nga sayo, bigyan mo ako ng testpoints at ng manual. Lahat ng electronic components ay dumadaan sa characterization sa production line. Yang characterization program, based yan sa datasheet ng component mo, andyan ang absolute maximum ratings, expected sway ng output mo at certain temp and frequency etc..
Kalokohan ang tanung mo na magvalidate ka pero di mo alam ang basis ng validation mo.
- Oct 2013
- 1,181
December 5th, 2015 11:09 PM #2477
- Mar 2015
- 65
December 5th, 2015 11:12 PM #2478
- Mar 2015
- 65
December 5th, 2015 11:16 PM #2479firmware definition from wikipedia:
In electronic systems and computing, firmware is a type of software that provides control, monitoring and data manipulation of engineered products and systems. Typical examples of devices containing firmware are embedded systems (such as traffic lights, consumer appliances, and digital watches), computers, computer peripherals, mobile phones, and digital cameras. The firmware contained in these devices provides the low-level control program for the device. As of 2013, most firmware can be updated.[1]
Firmware is held in non-volatile memory devices such as ROM, EPROM, or flash memory. Changing the firmware of a device may rarely or never be done during its economic lifetime; some firmware memory devices are permanently installed and cannot be changed after manufacture. Common reasons for updating firmware include fixing bugs or adding features to the device. This may require ROM integrated circuits to be physically replaced, or flash memory to be reprogrammed through a special procedure.[2] Firmware such as the ROM BIOS of a personal computer may contain only elementary basic functions of a device and may only provide services to higher-level software. Firmware such as the program of an embedded system may be the only program that will run on the system and provide all of its functions.
Before integrated circuits, other firmware devices included a discrete semiconductor diode matrix. The Apollo guidance computer had firmware consisting of a specially manufactured core memory plane, called "core rope memory", where data were stored by physically threading wires through (1) or around (0) the core storing each data bit.[3]
https://en.wikipedia.org/wiki/Firmware
December 5th, 2015 11:25 PM #2480
Of course, you should know what are those sensors and what they do. If they are activated what will happen.
You need something like this (quote ni crosswind below). Para malaman mo kung effective nga yung "1" or "0" mo.111
Only the automotive expert know it. A simulation also may not work. Pwede bang magpunta sa actual fight yung soon to be pilot na natapos sa flight simulator lang?Last edited by confused shoes; December 5th, 2015 at 11:27 PM.
