Page 143 of 493 FirstFirst ... 4393133139140141142143144145146147153193243 ... LastLast
Results 1,421 to 1,430 of 4928
    Mar 2013
    #1421
    Left-foot braking is for racing only?
    Left-foot braking technique is used in racing and there's no benefit gained from that in a regular daily drive.
    Kelan ko sinabing for racing lang??? Basahin mo ng maigi!
    Dangit, I do left foot braking after driving through a flood to dry up the rear drum brakes. That's the only benefit I get from left foot braking. Why do I have go a stretch to move my left foot to the right just to step on the brake pedal when in fact my right foot is closer to it.
    Now let's move on.
    Aug 2004
    #1422
    Quote Originally Posted by ClaNker View Post
    Now let's move on.
    You called someone here a wannabe racer for doing it. Honestly, reading the last few pages this morning, I couldn't believe the intensity of bile directed at one member here for driving in a slightly different and completely legal manner.
    There are benefits to LFB. Specifically because it ensures that you will not mistakenly hit the gas pedal when braking. Which is why we advocate two-foot braking in emergencies. Also, it reduces response time in cases where, if your feet or shoes are too big, your right foot can get snagged under the brake pedal during an emergency. The left foot, with that extra space on the left side in an auto, doesn't have that issue.
    Didn't mean to dredge it up, but I felt like it had to be said, is all. And LFB is actually a valid method of preventing SUA in auto-equipped vehicles.
    Apr 2014
    #1423
    Break lights did not light-up despite the claim that he stepped on the brakes.
    May 2008
    #1424
    mukhang yang video ng white montero na yan ang magpapahamak pa sa mga mag sasampa ng kaso sa MMPC kung talagang umapak siya sa brakes iilaw at iilaw ung brake lights nia, kahit nga nakapatay makina ng montero pag inapakan mo brakes umiilaw ung brake lights kalokohan naman na sabihin baka napundi un wow 3 ilaw ng brakelights napundi lahat edi dun pa lang obvious na kung ano klaseng driver siya.
    kasi sa pag atras nia pa lang you would expect na makikita mong nakailaw ung brake lights dahil kusang aatras yan ng dahan dahan pag naka "R" yan kaya alalay na lang sa brakes gagawin mo chaka ka lang aapak sa accelerator kapag nawalan ng momentum ung sasakyan or nag full stop ka at ung pag apak pa nga sa accelerator eh slight lng dapat cnu ba naman gagong aatras tapos isasagad ung accelerator.
    and it was clear na pinanggigilan nia ung accelerator sa taranta nia hindi uusok ung montero ng ganun hanggat hindi mo i-floor ung accelerator.
    #1425
    One of the first cases of MS SUA was dimissed because there was a video...yep, its a copy cat... Down to the smoking tailpipe. Takot mga litigants ikaso ang mmc kaya dinadaan sa trial by publicity.
    One of these cases has already been dismissed by the DTI in favor of MMPC, while the other two are pending, said the Mitsubishi executive.
    "There was one case in which the CCTV video clearly showed that the Montero Sport's brake lights weren't on upon impact, and that the exhaust pipe was even emitting smoke," Dytianquin told us. The driver, in other words, was stepping on the gas, not the brakes.
    Mar 2013
    #1426
    Because I would totally understand it if they go to a race track once in a while since that's where you can benefit from this driving technique.
    Big shoes on each tiny pedals that are too close to each other let alone your left leg squeezed towards your right during emergency. Yah best driving advice I've got.
    Please lang, if you want to advocate left foot braking then at least advice those who will do it to buy an after market brake pedal biased towards left foot braking. I'm sorry but in a stop and go daily reality drive... Good luck with your left foot braking on a right foot biased pedals. My argument is geared towards regular daily drive and pedals biased towards the right foot which all regular cars have. But please enjoy it if your car pedals is optimized for left foot braking, that's a blast in the corners.
    If don't get what I'm pointing at then that's not my problem anymore. Now can we move on please.
    Sep 2014
    #1427
    Hala, nagalit Sayo si niky. Lets not move on coz this needs to be resolved first .
    Pls continue ..
    #1428
    OB shutthe****up. the last thing we want here is an incendiarist.
    Let's move on. maganda yung usapan dito.
    Aug 2004
    #1429
    The problem is, you're misunderstanding the situation.
    There is no such thing as "right foot" or "left foot" braking pedals.
    Automatics have a big, horizontally arranged pedal, sitting in the exact center of the footwell that can be actuated by either foot. Moving either foot towards that pedal means you're already squeezing your legs together. (and again, best practice in an emergency is to have both feet on it!)
    Your suggestion is basically: "If you're going to tell people to use chopsticks with their left hand, tell them to use left hand chopsticks."
    I don't LFB because I learned RFB. But if you practice LFB and LFB only, there is no practical issue at all.
    I do feel that advocating LFB or at least instilling the instinct to two-foot brake can lessen the number of these incidents. Simply moving your left foot over to the brake will already tell you if your right foot is on the correct pedal.
    Mar 2013
    #1430
    Not all AT car have wide brake pedal comfortable for left foot braking, I'm squeezing my balls when I tried left foot braking in my old nissan. But it will be comfortable if I will put a left foot biased pedal in my car. Get the highlight?
    I would rather do regular heel toe braking method not the heel toe drifting technique. It's far more efficient and I don't have to switch driving style between manual and automatic. Matter of fact that's what I'm doing.
Mitsubishi Montero Sudden Acceleration Accidents [MERGED]
