Results 41 to 50 of 710
- Jan 2003
- 52
July 10th, 2007 06:07 PM #41Dear guys,
I have a 2001 Mitsubishi GSR. Dati wala syang problema sa mileage umaabot ng 9km/l strictly city driving. Tapus lately napasin ng erpat ko na biglang tumakaw bigla yun kotse. Ngayon lumalabas na sa 5 to 6km/l nalang. since this was kasa maintained dinala dun. Ang sabi ni ok naman daw according to the settings based on their computer readings etc. they also said that because the car is getting old lumalakas daw talaga... Dito ako di makapaniwala! What do you think is the problem with the car. I might bring it to rapide nalang. I feel na ginogoyo ako ng casa eh.
Your inputs are highly appreciated.
Cheers!
Russel
July 10th, 2007 08:29 PM #42
Hello Russel,
I am very sorry about your Mitsu casa experience. Anyway, I think your problem can be assessed sa www.mymitsuph.com
Sign in po kayo ang marami dun naka GSR. They might have encountered same problems as well.
Salamat po!
-Dreyiam3739.com
July 10th, 2007 08:42 PM #43
mas gogoyohin ka ng rapide wehehehe!
when was the last tune-up done? baka bad driving style lang or under-inflated tires? also take into consoderation yung fuel na ginagamit. baka you're not using the recommended RON as per manual?
i'd bring it to a more reputable shop. try mo si speedyfix if you're in the mandaluyong area. i can vouch for migs' service.
July 10th, 2007 08:56 PM #44
malakas talaga sa gas GSR pero di naman 5 to 6 km/l. mine is a 98 model pero nakaka 10 pako. baka tune-up lang kelangan dyan sir. pa check mo na lang sa mga trusted mechanics.
- Jan 2003
- 52
July 11th, 2007 08:51 AM #45Thanks sa mga nag rep. Anyway, As soon as we noticed that it was drinking gasoline pinatune up agad but it was still the same. anyway, the gasoline na gamit ko is usually shell na unleaded lang.
Ah talaga? Manggogoyo rin pala ang mga taga rapide? am in the manila area.
July 11th, 2007 10:39 AM #46
Try cleaning your MAF sensor with some electrical cleaner. While the ECU may report nothing wrong, poor fuel consumption can mean that one or two sensors may be very dirty, causing it to drink too much gas. This is a common problem on MAF-equpped cars like the Sentra and the Lancer.
Or it could be your AT is starting to go south... (I'm assuming your late-model GSR is INVECS) does it still shift smoothly?
- Jan 2003
- 52
July 11th, 2007 03:12 PM #47shifting is still ok. no problem with that. I'll try cleaning the sensors
thanks
R
October 19th, 2007 08:05 PM #48
[SIZE="5"]d best fuel consumption namin ay 11.91 kms/liter lang... tapos pag city driving na pang araw araw ay nasa 10 lang...
yug iba diyan?? mejo parehas lang b tyo?? di pa namin talaga magawa ang 12kms/liter and higher... kakapalit lang ng fuel injection pump namin and change oil, oil filter, ai filter, glowplugs.. 11.91 lang talaga best n nmin
ano p bang mga tips para mging 12km/liter or higher kahit city driving??
ako kc usually kapag tersera ay nasa 45kmh tapos iki kinta ko na kapag 65kmh... kaya ko na achieve ang 11.91km/liter ko..
ano p ba?? regular check up and maintenance nmn.. pasado nmn sa emissn test...
help.......[/SIZE]
- Nov 2006
- 316
Tsikot Member Rank 3
- Oct 2006
- 760
October 20th, 2007 09:22 PM #50Magagawa mo dyan acceptance.
Iwas traffic.
Top gear(w/o lug) asap.
Un!
