Results 1 to 4 of 4
July 27th, 2016 12:20 AM #1
is my 4m41 monty EGR valve busted ?
pina scan ko sa Denso sabi ng computer EGR Valve lang problem ,pinalinis ko and ni reset but bumabalik lang din yung check engine sign .. nag dadalawang isip ako kase i replace yung EGR ng montero kase same scenario ng 4d56 strada namin ni replace ang EGR valve sa casa pa ng Mitsubishi pero hindi rin nawala yung check engine sign at haggang ngayon hindi maipaliwanag ng casa bakit ganun yung strada
what should i do
- Jul 2016
- 939
July 27th, 2016 12:40 AM #2What exactly is the code??? Maraming code for EGR eh.
example;
P0401 - insufficient flow - pedeng barado egr, may boost leak(butas hose or Intercooler, sira maf sensor.)
P0402 - over flow - stuck up/open egr valve, baka makuha pa sa linis or sira na mismo solenoid or sira ung position sensor, maf sensor.. may butas hose ng vacuum line if vacuum actuated ang egr opening/closing.
P0490 - high circuit - shorted egr valve or ung wiring harness pa puntang ecu.
Etc, etc... Dapat alam mo particular code, then alam mo ung egr system nya para para maayos. Di yung lumitaw egr fault eh palit egr agad....
July 27th, 2016 10:45 AM #3
May ganyan palang code sa scan, sa Mitsubishi kase basta lumabas sa Egr. Replace agad. Saan ba recommended na shop na pwede talaga mahuli yung pinaka check engine
- Mar 2013
- 2
March 14th, 2018 09:57 PM #4I was searching to find solution for the same problem you have. My check engine light on my 2007 Strada 4M41 is lit. I had it checked and the error code na lumabas is P2413. Prior to this the trouble code was also for the Barometric Pressure and MAP airflow, may leak yata yung vaccum hose. Pinalitan na yung hose. Ok siya for a while then nag-check engine lit ulit which was the P2413. Nilinis nila yung EGR valve, but still the CEL (Check Engine Light) ay umiilaw. To this day naka-ilaw pa rin siya.
I noticed that when we are up north sa Baguio, once the engine has cooled after the long travel, and I start it up, wala na yung CEL. All through out pag nasa Baguio kami, wala CEL. But when we go down to Manila na, after a stop over somewhere sa lowlands, mag CEL ulit siya. Sabi nila sa Barometer daw yun, pero hindi naman Baro pressure code ang lumalabas sa scan ng CEL. I'm using a OBDII scanner to check the CEL.
I hope to hear from you if mayroon na kayo findings. Ayaw ko din palitan agad yung EGR if hindi sigurado na for replacement. As you said, pinalitan na yung sa inyo pero may CEL ON pa rin.
Tesla Philippines
