Results 1 to 4 of 4
    Jun 2009
    Good day sirs, my 2012 4x4 strada has a 265x70R17 tires. I noticed it has an uneven tire front right tire. So, I brought it to a local tire shop here in the province. They have a complete computer/laser guided tire alignment system here, so I thought ok na. Mali pala, after the "adjustments", now my pick-up slightly wanders to the left. By the way I had the rear tires placed in the front.
    May I ask, if I can have the proper, caster, camber and toe of the strada? Thank you.
    Sep 2012
    Hindi mo na try i claim sa kanila as back job?
    Possible causes ng ganyang problem
    * Incorrect front wheel alignment
    * Worn steering or suspension joints, bushes or components
    * Roadwheel out of balance
    * Faulty or damaged tyre
    * Wheel bolts loose
    * Defective shock absorbers
    if your tires are out of round ("oblong"), no amount of adjusting will make your ride go straight. (well, it might go straight pa-abante, but not when you drive backward.)
    it's easy to check: remove the wheel and roll it. it should go straight.
    Jun 2009
    Thanks for the input sirs.... Brought my unit to a reliable wheel center, have to travel an hour though. Normal na. Haay salamat...
Strada wander to the left
